How can i create a slider only for the head in cc3 ???
Posted By hj 8 Years Ago
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
Hi Peter,
Actually just last night I finally figured out why I was having this problem, it has something to do with having my template and custom folders on a USB drive, which worked fine until iC7.3 apparently.
WHAT I DID:
In a last ditch effort I uninstalled all Reallusion products on the desktop computer, cleaned out all references to those products, rebooted and then reinstalled the Hub.  I used the Hub to reinstall everything in the order on the list, but this time, since I have enough hard drive space on this computer, I just installed everything to the "C" drive and not the USB then rebooted again.  After that I proceeded to reinstall content then tried again to save a head and avatar and was able to do so without any problems!  I'm not sure why iC7.3 doesn't like my USB Drive, it's the same one I used with iC6 and didn't have these problems with it.  I should mention that only saving heads and avatars were the issues that iC7.3 seemed to have with using content on the USB drive.
Now the laptop is a different issue because it doesn't have a big enough hard drive to install everything to, the content has to be on a USB drive until I can save up to install a bigger second hard drive to it and, as it turns out, that is probably several months away at this point.  So if we can figure out what is causing this USB issue with iC7.3, that would be greatly appreciated!
I'll wait a little longer to see if someone figures it out before submitting a support ticket, I might try a newer USB drive first to see if the older one has developed issues that is causing this, if that doesn't work then by all means I'll submit the ticket.
Dorothy Jean
Dorothy Jean
Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)Distinguished Member (4.4K reputation)
Posts: 266, Visits: 1.1K
As far as i know this can only be done in iclone. If i am wrong please let me know!
https://forum.reallusion.com/uploads/images/dbdccbe9-2417-45d2-b87d-7b31.jpg
Snarp Farkle
Snarp Farkle
Hi Dorothy Jean,
Yeah this thread is about creating head sliders in CC3, but to do that you need to be able to save a head in iClone then reference it in CC3 when creating the head slider.  I was not able to do that because the button was greyed out, as it turns out I had to uninstall iClone and reinstall using the downloaded .exe file instead of using the HUB to reinstall, everything worked after that.
However I am back to having the same problems again after the 7.4 update, I checked all the file permissions and had to reset them again but that's a windows update problem not a iClone problem but it didn't fix the problem, so I'll try to uninstall and reinstall again using the downloaded .exe file instead of the HUB version and see if that works again like before.
[EDIT]
Well that didn't work this time, the only thing I didn't do this time is reinstall everything Reallusion and don't really want to do that again if I can avoid it, my pic for the magazine is due now and even though I can make due with what I have I'm back to not being able to save anything in iClone except for projects.
https://forum.reallusion.com/uploads/images/b05f052b-37f7-4324-a27f-4fbd.png
Any clues?
Snarp Farkle
Snarp Farkle
Just for the heck of it I uninstalled and reinstalled iClone again using the downloaded .exe installer, but this time using the C: drive for template and custom storage and everything works again!
Not sure why this is happening still, but I'm leaning towards it being a Windows update making some mystery changes rather than iClone misbehaving, Windows must be changing something that has to do with USB Drives is all I can think of at this point. :unsure:
https://forum.reallusion.com/uploads/images/5c4be042-1d92-44f8-950a-2754.png
The laptop's version is working fine on the USB Drive as storage, so not sure at all what's going on but I can use the save features now, so I'll just chock it up as another stupid Windows mystery!
Last Active: 4 days ago
It shouldn't but does Windows perhaps change the drive letter of your USB drive?
Posts: 5.3K, Visits: 16.8K
animagic (2/28/2019)
That is most likely the cause. And to overcome, a drive should be reassigned to some letter at bottom of the alphabet. Like an "X" for instance.
This can be done in Disk Management (Win+R > diskmgmt.msc).
And it should be done before iClone is re-installed and pointed to a new drive path of course.
Snarp Farkle
Snarp Farkle
@animagic, @4u2ges,
Thanks guys for responding, the drive letter is still the same as it's been since I first added it last year, even after reinstalling Windows 3 times.  I have 6 USB drives that stay hooked up all the time so that I can avoid that issue.  If I have to reinstall iClone again I will try changing the drive letter as 4u2ges suggested.
It would have been better if I was the only one who had "greyed out buttons", then I wouldn't be so confused I think. :ermm:
The only USB drive I've had problems with is the DAZ drive, it likes to freeze up now and then just in case I get too comfortable with things working well I guess! :laugh:
