Issues & Suggestions
Posted By Miranda (RL) 10 Years Ago
6
7
18
eternityblue
eternityblue
Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)
Posts: 769, Visits: 2.7K
I have gotten CC to crash several times by importing a large accessory and then adjusting the key lights. The accessory was actually a house, but still. Crash!
My system: i7 3770 Gtx1060 6GB
Posts: 5.7K, Visits: 26.5K
eternityblue (12/31/2016)
Let's be honest, a house isn't an accessory - unless you are a Turtle!!
Zeronimo
Zeronimo
Posts: 482, Visits: 19.3K
Delerna (12/31/2016)
press ctrl and forward slash to bring up the gizmo if memory serves me correctly. Hmmm maybe back slash. well one of the slashes I'm getting tired. End of day for me
on a french keybord (azerty) I have to press CTRL+Shift+Forward Slash to obtain the gizmo
it works with the default avatar and default background, but nothing move's.
As soon I load the base Female or change the default atmosphere and press Ctrl+Shift+Forward Slash the program crash.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)
Posts: 1.2K, Visits: 7.2K
zeronimo (12/31/2016)
On a french keyboard, you have to press CTRL+/ (from the Numeric Pad) in order to rotate the IBL.
CTRL+SHIFT+/ (main Keyboard) will act the same as SHIFT+/ (main Keyboard): It will rotate a Light (not the IBL).
In short, to rotate the IBL you have to use the "/" from the Numeric Pad.
guy rabiller | GOETZIWOOD STUDIOS
"N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
Posts: 8.2K, Visits: 26.5K
grabiller (12/31/2016)
@justaviking
This is not a bug. When you load another Atmosphere, the check box "Sync Sky Image" becomes unchecked, that's why now the lighting and background are "unsynced" when you use CTRL+/.
If you check back that check box then both lighting and background will follow accordingly.
Not a bug but perhaps this check box should be kept checked after Atmosphere change to avoid confusion indeed.
Thanks for the info.
I'll check that out, and then add a comment to the Issue I reported.
I guess I'd call it a "different bug."  I think it should preserve the "Sync" option you set, even when changing atmosphere.
On my "English" keyboard, I used the "/" on the main keyboard area.
I found what I thought was a bug:  https://forum.reallusion.com/FindPost309558.aspx
I still think it's a bug, but maybe not the one I thought.  Apparently the "Sync" option get's un-checked when you change Atmosphere.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
justaviking (12/31/2016)
@justaviking
../..I think it should preserve the "Sync" option you set, even when changing atmosphere.
I agree.
The french (and possibly other country) keyboard issue is unrelated to the unchecked "Sync Sky Image" checkbox.
On a french keyboard you have to use SHIFT to get the "/" sign from the main Keyboard, while you get it directly on an English main keyboard.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
For Your Information:
Morph Slider Editor Does Not Remember Slider Path
Kevin.S
Kevin.S
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.2K, Visits: 71.8K
Getting some crashes
https://forum.reallusion.com/uploads/images/bd3576aa-8fd1-44ab-be38-90e.jpeg
Freelance Artist Kevin.S
https://forum.reallusion.com/uploads/images/57cedd8e-58c4-42ce-b2f4-9646.png https://forum.reallusion.com/uploads/images/5a59e070-66a0-4914-b0a5-b2dc.png
Email: animatemyart@gmail.com - Web Site:  www.animatemyart.com
Posts: 8.2K, Visits: 62.6K
This beta does not yet export compatible iC7 content. That is written up in the introduction.
6
7
18
