Galfridus
Galfridus
Posted 10 Years Ago
Visits: 2.2K
 Starting at 0.07 in the Character Creator 2.0 Beta - Visual Enhancements vid there is a brief sequence where the rotate gizmo is used to horizontally revolve the "IBL sky" whilst the avatar remains stationary. Try as I may, I can`t duplicate this method to observe the changing play of light on my avatars face. Even affetr selecting sky the "Rotate" remains stubornly greyed out so the gizmo doesn`t appear. I can of course rotate the entire scene with the Camera but that doesn`t reproduce the effect demonstrated in the vid. Hopefully I am making some very basic error, which eludes me, and a more knowledgable user may kindly point me in the right direction ? Geoff.
Delerna
Delerna
Posted 10 Years Ago
Posts: 1.5K,
Visits: 14.8K
press ctrl and forward slash to bring up the gizmo if memory serves me correctly. Hmmm maybe back slash. well one of the slashes I'm getting tired. End of day for me
i7-3770 3.4GHz CPU 16 GB Ram GeForce GTX1080 TI 11GB Windows 10 Pro 64bit
Zeronimo
Zeronimo
Posted 10 Years Ago
Visits: 19.3K
rampa (12/31/2016) There can be up to 18 layers of clothing. If you add a piece of clothing that has the same layer assignment as one on the character, it will replace it. So....What you want to do is set the piece of clothing that is disappearing to a different layer. The layer settings are in the bottom of the "Conform" panel. Conform is in the toolbar.Thank you Rampa. Indeed my problem is solved.
Galfridus
Galfridus
Posted 10 Years Ago
Visits: 2.2K
Delerna (12/31/2016) press ctrl and forward slash to bring up the gizmo if memory serves me correctly. Hmmm maybe back slash. well one of the slashes I'm getting tired. End of day for meThank You very much Delerna for prompt and helpful reply. CTRL+forward slash was what I needed to know to make it work. :)Geoff.
Posted 10 Years Ago
Posts: 5.7K,
rampa (12/30/2016) EDIT: Nevermind. It's just a different icon in CC 2! :blush:
I'm also curious if CC 2 will get the color adjust panel, for adjusting the non-Substance (or baked) texture channels.The option is available for both Classic and PBR materials, they used a different icon in CC. :pinch::crazy:
Posted 10 Years Ago
Galfridus (12/31/2016)
Delerna (12/31/2016) press ctrl and forward slash to bring up the gizmo if memory serves me correctly. Hmmm maybe back slash. well one of the slashes I'm getting tired. End of day for meThank You very much Delerna for prompt and helpful reply. CTRL+forward slash was what I needed to know to make it work. :) I'm seeing what I think is a bug here. 1) Open the "Base Female" project 2) Press and hold Ctrl-/ and use the left mouse button to rotate the gizmo horizontally... works fine... background image rotates 3) Open the Atmosphere panel, and apply a different background 4) Repeat Step #2... the light changes, but the background does not move Bug? If anyone agrees, I'll report it. If not, please explain why not. UPDATE:Duchess concurred, so I logged it. Issue #1970: http://www.reallusion.com/FeedBackTracker/Issue/Background-image-will-not-rotate-after-you-change-environment-image
duchess110
duchess110
Posted 10 Years Ago
Last Active: 6 Years Ago
Posts: 2.0K,
Visits: 15.5K
justaviking (12/31/2016)
Delerna (12/31/2016) press ctrl and forward slash to bring up the gizmo if memory serves me correctly. Hmmm maybe back slash. well one of the slashes I'm getting tired. End of day for meThank You very much Delerna for prompt and helpful reply. CTRL+forward slash was what I needed to know to make it work. :) I'm seeing what I think is a bug here. 1) Open the "Base Female" project 2) Press and hold Ctrl-/ and use the left mouse button to rotate the gizmo horizontally... works fine... background image rotates 3) Open the Atmosphere panel, and apply a different background 4) Repeat Step #2... the light changes, but the background does not move Bug? If anyone agrees, I'll report it. If not, please explain why not. Yes followed your steps and the same thing happens background stays only lights move.
Duchess Designs Store
Posted 10 Years Ago
duchess110 (12/31/2016)Yes followed your steps and the same thing happens background stays only lights move. Thank you. Issue #1970: http://www.reallusion.com/FeedBackTracker/Issue/Background-image-will-not-rotate-after-you-change-environment-image
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posted 10 Years Ago
Posts: 1.2K,
Visits: 7.2K
@justaviking This is not a bug. When you load another Atmosphere, the check box "Sync Sky Image" becomes unchecked, that's why now the lighting and background are "unsynced" when you use CTRL+/. If you check back that check box then both lighting and background will follow accordingly. Not a bug but perhaps this check box should be kept checked after Atmosphere change to avoid confusion indeed.
-- guy rabiller | GOETZIWOOD STUDIOS "N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posted 10 Years Ago
Posts: 1.2K,
Visits: 7.2K
For Your Information: TipTool Messages For Metallic and Roughness Slots Are InvertedI just realized I should have called those "ToolTips" lol. Sorry about that.
