Did 5.5 release work out the 100% cpu usage with Nvidia cards?
Posted By FreddyKrueger 13 Years Ago
planetstardragon
planetstardragon
Posted 13 Years Ago
Posts: 11.5K, Visits: 46.0K
@prabhat - i can answer this one. to a degree, prior to my current card - I had a gt 9400 and was having the same issues as Lynn....then I upgraded to my 460 and my cpu was slowing my card down - now I upgraded my cpu ..and my drive is slowing the process down - so I found for best performance you really need a balanced computer build because each part plays it's role. if the cpu is choking, it will choke everything else with it. - iclone will perform as fast as your slowest part. The gpu matters for being able to hit play and watch whats happening on screen - the cpu matters for all the reasons I've mentioned earlier in this thread - and the memory matters for reasons that Animagic pointed out by enabling xmp and having iclone run faster ...and finally the drive matters for load and save to disk times. So having anyone of these more powerful than the other is moot, if the slowest part is slowing everything else down.
@ lynn - the gtx 650 is a nice card, it's faster than my current card and I'm blazing through iclone. it ranges from us $119 - 180'ish - depending on what manufacturer and options you get on it - ie a regular 650 or a 650 ti boost. an even better card that is great for the price is the gtx 760 which runs about 250 ( which is a great price for a 700 series video card - ie compared to the 780 which runs about $660 )
prabhatM
prabhatM
Posted 13 Years Ago
Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)Distinguished Member (6.6K reputation)
Posts: 1.8K, Visits: 8.1K
planetstardragon (8/29/2013)
One part is general fast screen refresh, the other is actually transferring the load of processing and rendering to GPU. As far as I know DAZ does not have the support for GPU as yet. So I want to know in unambiguous/clear terms if ICLONE supports GPU in real sense.
Sifr
Sifr
Posted 13 Years Ago
Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)
Posts: 647, Visits: 3.7K
YES!!!! :D
iClone most certainly does use GPU, it doesn't take full advantage of single or multi-threaded SLI GPU(Dual 2x 2GB GTX 680m), meaning iClone isn't optimized to do so, but basically your gpu is responsible for displaying the point space in real-time with shaders so that's the points lines and faces = polygons, moving onscreen so ideally the faster the GPU+memory size = how many frames per second you will get with all the bells and whistle on i.e. motion, atmospheric, physics, particles, post processing , large scene elements(poly-count), lens effect.
The CPU on the other hand is responsible for calling the commands that you tell it into GPU memory or system memory, when you change a field, or open a prop, or pressing play, but once it is displayed, it's on the GPU (hopefully Dedicated and not Integrated or Embedded graphics), so if your CPU is fast & your GPU is slow, or vise-verse, iClone will be inherently slow.
There is a limit on what even the most powerful computers can do, unless you stack a CPU/GPU render farm into infinity-X-infinity.
Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen.  CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron Ready:):D:P;):cool::hehe::smooooth::crazy::satisfied::Wow::pinch::exclamation::alien::discuss::kiss::arrow::(:angry::sick::exclamation::blush::Whistling::w00t::w00t::w00t:
SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX
Dell  Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus
Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen
Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
lynn3d
lynn3d
Posted 13 Years Ago
Last Active: 11 Years Ago
Posts: 297, Visits: 487
planetstardragon thank you for this comprehensive explanation and for the specs and prices of the cards, much appreciated :)
Unfortunately, I'm not aiming for the Oscars and I would like to get this project finished before Xmas and so compositing is pretty much out of the question.
The problem scene already has everything deleted which is not in the view port so there is nothing to gain there either.
Thank you as well, I'm looking into upgrading my graphics card and adding more memory
In the meantime, I did a restore point to bring back v5.4 but now - on loading iClone - I'm having a problem with the script debug telling me :
Fail to call OnUpdateGUI [string "--[[ TextLine..."]:69: attempt to call method 'CalculateTextDrawHeight' (a nil value)
and I can only close iClone again.
Please, how can I fix this ??? :crying:
Animations made in iClone and CrazyTalk Animator
colour
colour
Posted 13 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
lynn3d (8/29/2013)
Lynn
Windows System Restore  is a Diagnostic Tool for identifying if a particular Hardware / Software change is the cause of eg; a Windows OS Stop Error Message (BSOD). It doesn't have any effect on reverting back-to an earlier version of a Program, to debug any faults in a later Version. Putting it simply.;) More often than not, it can make matters worse, as you've found-out.
Go back into System Restore & undo that Restore Point.
BTW- Your Project was created in iC5.4 & IMO,  has now been converted to iC5.5 Project File Format. IMO, you can't now Open your Project in iC5.4
I hope you have backed-up your Project?
If you can't Open your Project in iC5.5, IMO you should start a new Thread dedicated to your problem, Copying what you've Posted here into that Thread for background information & take it from there..
Anyone-else?
      REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
planetstardragon
planetstardragon
Posted 13 Years Ago
btw, I'm using virtu MVP - a nifty little software that uses a combination of any cpus that have built in gpu / video - no conflicts with iclone so far and seems to be helping a lot - almost like having sli - 2 video cards - I can only speak for my system though as the motherboard came with the software - i really don't feel any need to upgrade my gtx 460 at the moment, not sure if part of that credit belongs to virtu.
http://www.lucidlogix.com/product-virtu-mvp.shtml
Posted 13 Years Ago
lynn, if you still have the 5.4 patch file you could try to reapply that.
But, I've experienced the same problem that you are having after a system restore: a non-functional iClone (I thought I could revert, which, in theory, is possible according to MS).
If you still have your older install files, you could try to uninstall and reinstall up to 5.4.
colour
colour
Posted 13 Years Ago
animagic (8/29/2013)
Lynn
Read my Post above first.
lynn3d
lynn3d
Posted 13 Years Ago
Thank you all :)
I have just completely uninstalled iClone and reinstalled up to v.5.41 and everything works fine again. Only the one file that I had started in v.5.5 is not backward compatible but that's no problem for it's easy enough to set it up again.
At least now I can continue to use the software until I can upgrade my PC but not looking forward to it :(
FreddyKrueger
FreddyKrueger
Posted 13 Years Ago
Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)
Posts: 97, Visits: 468
Good stuff, glad this thread is helping. :D
Alienware 15, i7 4710hq, GTX 970m, 16gb ram, 4k display, 1.5TB SSD raid.
