brothertcoleman
brothertcoleman
Visits: 6.1K
Is it possible to get an option for more finger control in the 2D Motion Key Editor for bone hands ,its hard to fine tune the fingers, could there be a zoom in function to see better and possible more control like in the Motion Live 2D finger panel?
kylelee
kylelee
Visits: 4.2K
brothertcoleman (11/20/2020)
Is it possible to get an option for more finger control in the 2D Motion Key Editor for bone hands ,its hard to fine tune the fingers, could there be a zoom in function to see better and possible more control like in the Motion Live 2D finger panel? ![https://forum.reallusion.com/uploads/images/add60c74-b0c7-4b1d-98e7-dcd8.png](https://forum.reallusion.com/uploads/images/add60c74-b0c7-4b1d-98e7-dcd8.png) The main function of Hand Pose Editor is to help adjust the hand pose, you can click on the specific bone through hierarchy to fine-tune the pose.
There's a "Finger Rotation" function in the Motion Live 2D control panel. You can adjust the strength of the fingers' rotation through the slider when recording the motion. Could you tell me more about which a scenario you need to adjust the finger rotation?
4 Years Ago by
kylelee
brothertcoleman
brothertcoleman
Visits: 6.1K
I was thinking an easier process but I can make it work .
Another question please ,is the bone hands on the new dummy characters updated from the others ones ,the angle seems to work better when applied to characters? If so I will try to edit some colors for different skin complexions for custom characters, it’s a lot of work so I wanted to know before I started.
Thank you
kylelee
kylelee
Visits: 4.2K
brothertcoleman (11/22/2020) I was thinking an easier process but I can make it work .
Thank youYes, this is a new dummy character, we have provided in Download Resource, which you can use directly. Here you are: CTA4.4_BetaContent.zip
4 Years Ago by
kylelee
brothertcoleman
brothertcoleman
Visits: 6.1K
Thanks
Magical Kingdom
Magical Kingdom
Visits: 187
Apart from a bit fiddly to get it going, once it is working, the synchronisation is quite amazing. Ok, it does not do the 360 degree body turn at the end of the routine but the animation is still very smooth and accurate. Perhaps such motion detection could be implemented by Reallusion in the later versions. Well done Reallusion development team.
Minnie (RL)
Minnie (RL)
Group: Moderators
Visits: 913
@ Magical KingdomThanks for the kind word, the product team are dedicated to developing the features that users would think it's helpful, it's very encouraging to receive your comments. We will keep improving the product. As for the current version, you can try some features such as "lock to hip" & "flip body" to make the motion perform better. You can refer to https://forum.reallusion.com/FindPost464019.aspx, if it helps
kylelee
kylelee
Visits: 4.2K
Hi Magical Kingdom, Once the 3D motion is applied, you can adjust layer order with Layer Editor (so that the hand can appear to the front) and change the hand sprite with Sprite Editor. These might help to make these motion more nature ![Smile](https://forum.reallusion.com/Skins/Classic/Images/EmotIcons/Smile.png) )
4 Years Ago by
kylelee
