Snarp Farkle
Snarp Farkle
Visits: 3.6K
Joanne (RL) (4/17/2018)
Request for Users' Help
We need your help to collect information on Daz packs, especially those with auto-hide mesh enabled. If you have encountered an error with auto-conversion in 3DXchange, please provide us with the Daz Pack name and its link in the Daz store. It will help us tremendously in the quality control process with future versions of 3DXchange and CC3 Solo product.
Thank you! Realluson iClone Team There are some items with hidden mesh that have a long list of hidden surfaces like the ArcTek Cyber items and you must select all of them down to the "}," as in your description. This confused me the first time I tried this method as I only selected and deleted "graft" : {", silly of me I know but it took me a couple times to realize that I had to select all of them. :Whistling:
SpaceCore
SpaceCore
Visits: 496
That is awesome! Thank you! I did get Buddy Bot and Scrappy both imported finally (although Buddy Bots finger bending is bizarre). On your Scrappy... Were you able to import him with his facial morphs and poses? I have watched a half dozen tutorials and still not seeing anything that helps with getting the morphs into iClone as the Daz resource key does not seem to work for the bots either
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
SpaceCore
SpaceCore
Visits: 496
Thank you! I will give it a shot now and post an update if I ever smartened up :-)
larryjbiz
larryjbiz
Last Active: 3 hours ago
Visits: 6.3K
You also may need to put the body manually into a T-pose  I had to do that with this guy... The arms didn't go completely up into T pose...I manually adjusted them
larryjbiz
larryjbiz
Visits: 6.3K
For most of the problems I have had with the chest, it has usually been moving just one bone designation.
I choose the Daz profile. And then I use the arrow key to open up the bone for spine. The bone section I want to change is located the 2nd notch up. I want the very bottom. I click on the bottom bone section and assign it to y shape bone on the character above the hip. I know I'm not stating it very well, I'll post some pics when I get home if you haven't already got a fix.
Thanks
SpaceCore
SpaceCore
Visits: 496
Could anyone advise on what I am doing incorrectly here? I have two robots that I purchased from Daz (links to packs below) and when converting in the updated version of 3dxchange, the torso separates from the body and the Daz T-Pose in the Reallusion folder does not apply. Can anyone offer any suggestion on what is going on? I am sure it must be operator error. https://www.daz3d.com/buddy-bothttps://www.daz3d.com/scrappy-the-robot
Posts: 23.1K,
Visits: 36.6K
Tenderspirit (7/4/2018)
Admin: I am not sure what I did but I solved the problem. Thank you for trying to help. I moved all my origional genesis 3 and 8 to My Daz 3 Library, they were in another folder that I install a bunch of stuff for Daz. Not sure if that is what fixed it or not. LOL But they seem to work now. :>) Thank you for trying to help. Hugs Thanks for letting us know you were able to resolve the problem. :)The Daz folder structure can cause problems especially if you try to customise it so that may have been the problem.
Tenderspirit
Tenderspirit
Visits: 223
Tenderspirit
Tenderspirit
Visits: 223
Yes I copied it to the correct path. Now when I try to appy my gen 8 male it too does not work, I am using the Pace figure in Daz. So far only the Paige gen 8 figure has worked for me. I don't have any other gen 8 daz figures only Paige and Pace and the origional. I will try the origional male later today and see if he works. ugh Thank you for your help so far. Hugs
