[v7.21] - Workaround for the Failure to Auto-convert Daz Genesis Characters
Posted By Joanne (RL) 7 Years Ago
3
4
5
[v7.21] - Workaround for the Failure to Auto-convert Daz Genesis...
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
Joanne (RL) (4/17/2018)
Request for Users' Help
We need your help to collect information on Daz packs, especially those with auto-hide mesh enabled.
If you have encountered an error with auto-conversion in 3DXchange, please provide us with the Daz Pack name and its link in the Daz store.
It will help us tremendously in the quality control process with future versions of 3DXchange and CC3 Solo product.
Thank you!
Realluson iClone Team
There are some items with hidden mesh that have a long list of hidden surfaces like the ArcTek Cyber items and you must select all of them down to the "}," as in your description.  This confused me the first time I tried this method as I only selected and deleted "graft" : {", silly of me I know but it took me a couple times to realize that I had to select all of them.  :Whistling:
SpaceCore
SpaceCore
Posts: 67, Visits: 496
That is awesome! Thank you! I did get Buddy Bot and Scrappy both imported finally (although Buddy Bots finger bending is bizarre).  On your Scrappy... Were you able to import him with his facial morphs and poses?  I have watched a half dozen tutorials and still not seeing anything that helps with getting the morphs into iClone as the Daz resource key does not seem to work for the bots either
https://forum.reallusion.com/uploads/images/83007e36-ccb5-453f-8d89-9eb5.png
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
https://forum.reallusion.com/uploads/images/0bc633c4-589d-4d31-a9c7-476e.png
Buddy Bot works but i had to cheat a bit:
(i'm not an expert, there is probably a workaround that is more elegant, but it works)
Buddy Bot is quite BIG, so i had to make more pix to show the rig...
https://forum.reallusion.com/uploads/images/cb62b989-a858-44b5-addb-717f.png
https://forum.reallusion.com/uploads/images/4709c734-05c5-456e-aa53-9656.png
https://forum.reallusion.com/uploads/images/79060148-fb63-4da4-b987-b517.png
https://forum.reallusion.com/uploads/images/ad9655e7-c367-42e3-8b7a-e3c2.png
I had to use the shoulder here instead of his upper arm...
https://forum.reallusion.com/uploads/images/0338fde5-c569-40f9-bc1b-5885.png
https://forum.reallusion.com/uploads/images/3f08f5a3-2b52-458e-b5b8-80d2.png
https://forum.reallusion.com/uploads/images/70ad8e24-f017-4034-a22e-f0e0.png
Scrappy is quite easy, use "DAZ 4 genesis" AND lower the second green (red dot) to the green one under it and click the chest rig...
https://forum.reallusion.com/uploads/images/5798e5f1-101a-4135-aa26-7299.png
Hope that helped...
Here you can see Buddy Bot in action :D
SpaceCore
SpaceCore
Thank you! I will give it a shot now and post an update if I ever smartened up    :-)
larryjbiz
larryjbiz
Last Active: 15 hours ago
Posts: 342, Visits: 6.3K
You also may need to put the body manually into a T-posehttps://forum.reallusion.com/uploads/images/63f75801-8ddd-4b3e-a76b-a2e0.png
I had to do that with this guy... The arms didn't go completely up into T pose...I manually adjusted them
larryjbiz
larryjbiz
For most of the problems I have had with the chest, it has usually been moving just one bone designation.
I choose the Daz profile. And then I use the arrow key to open up the bone for spine.
The bone section I want to change is located the 2nd notch up. I want the very bottom.  I click on the bottom bone section and assign it to y shape bone on the character above the hip.
I know I'm not stating it very well, I'll post some pics when I get home if you haven't already got a fix.
Thanks
SpaceCore
SpaceCore
Could anyone advise on what I am doing incorrectly here? I have two robots that I purchased from Daz (links to packs below) and when converting in the updated version of 3dxchange, the torso separates from the body and the Daz T-Pose in the Reallusion folder does not apply. Can anyone offer any suggestion on what is going on? I am sure it must be operator error.
https://www.daz3d.com/buddy-bot
https://www.daz3d.com/scrappy-the-robot
https://forum.reallusion.com/uploads/images/a248e216-f37a-443a-bfcf-8744.png
Posts: 23.1K, Visits: 36.6K
Tenderspirit (7/4/2018)
Admin:  I am not sure what I did but I solved the problem.  Thank you for trying to help.  I moved all my origional genesis 3 and 8 to My Daz 3 Library,  they were in another folder that I install a bunch of stuff for Daz.  Not sure if that
is what fixed it or not. LOL  But they seem to work now. :>)  Thank you for trying to help. Hugs
Thanks for letting us know you were able to resolve the problem. :)
The Daz folder structure can cause problems especially if you try to customise it so that may have been the problem.
Tenderspirit
Tenderspirit
Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)Senior Member (483 reputation)
Posts: 13, Visits: 223
Tenderspirit
Tenderspirit
Yes I copied it to the correct path.  Now when I try to appy my gen 8 male it too does not work, I am using the Pace figure in Daz.  So far only the Paige gen 8 figure has worked for me.  I don't have any other gen 8 daz figures only Paige and Pace and the origional.  I will try the origional male later today and see if he works. ugh   Thank you for your help so far. Hugs
3
4
5
