Need Help with AML Props
Posted By annmdouglas_20110504212021... 15 Years Ago
Posted 15 Years Ago
Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)Veteran Member (881 reputation)
Last Active: 12 Years Ago
Posts: 32, Visits: 188
I can't seem to get my AML templates to show up once I place them on my set as they do in the tutorial; I only see the yellow "select" lines; consequently, I can't seem to be able to get my props to attach to them.
Can anyone help?
Ann
bobdoyle
bobdoyle
Posted 15 Years Ago
Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)
Posts: 185, Visits: 639
I have this same problem? Any suggestions from anyone??
Meet Bob Doyle
World's Greatest (iClone) Interview with Bob Doyle
Posted 15 Years Ago
Please check to make sure that the AML Template is not set to Hide in Scene Manager. When an object is set to Hide you will only see the yellow selection frame. Also make sure it is not being hidden in a floor prop. If you are using a floor prop try raising the AML Template on the Z axis a little (or lower the floor accordingly).
If the problem still exists after you have checked this then please contact Support using the link below. They will be able to help you further with this problem.
Also please remember to ensure that your version of iClone is updated to the latest available.
