Need Help with AML Props
https://forum.reallusion.com/Topic84506.aspx
Print Topic | Close Window
By annmdouglas_20110504212021317 - 15 Years Ago
I can't seem to get my AML templates to show up once I place them on my set as they do in the tutorial; I only see the yellow "select" lines; consequently, I can't seem to be able to get my props to attach to them.
Can anyone help?
Ann
By bobdoyle - 15 Years Ago
I have this same problem? Any suggestions from anyone??
By Peter (RL) - 15 Years Ago
Please check to make sure that the AML Template is not set to Hide in Scene Manager. When an object is set to Hide you will only see the yellow selection frame. Also make sure it is not being hidden in a floor prop. If you are using a floor prop try raising the AML Template on the Z axis a little (or lower the floor accordingly).
If the problem still exists after you have checked this then please contact Support using the link below. They will be able to help you further with this problem.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Also please remember to ensure that your version of iClone is updated to the latest available.
