JEM618
JEM618
Posted 2 Years Ago
Visits: 168
CTA5. From what I can find, there are only two aspect ratios: 4:3 and16:9. I'd like to use 9:16. For now, I've created a white 16:9 PNG to denotethe safe zone, but it seems there must be a better way. Is there a way tochange the aspect ratio? Can the safe area of the stage be adjusted to reflectthis, or could a template be created?
Posted 2 Years Ago
Posts: 23.1K,
Visits: 36.6K
Hi... You are not restricted to just two aspect ratios. You can set the aspect ratio to anything you want. So in the example below, I changed the resolution in the Render Video panel to 1080 x 1920 (9:16) which is then reflected in the viewport.
JEM618
JEM618
Posted 2 Years Ago
Visits: 168
Wow, that’s amazing!! I’d never have found that. Thanks so much. Jim
