Safe Zone aspect ratio
https://forum.reallusion.com/Topic554236.aspx
Print Topic | Close Window
By JEM618 - 2 Years Ago
CTA5. From what I can find, there are only two aspect ratios: 4:3 and16:9. I'd like to use 9:16. For now, I've created a white 16:9 PNG to denotethe safe zone, but it seems there must be a better way. Is there a way tochange the aspect ratio? Can the safe area of the stage be adjusted to reflectthis, or could a template be created?
By Peter (RL) - 2 Years Ago
Hi...
You are not restricted to just two aspect ratios. You can set the aspect ratio to anything you want.
So in the example below, I changed the resolution in the Render Video panel to 1080 x 1920 (9:16) which is then reflected in the viewport.
https://forum.reallusion.com/uploads/images/b279d0f4-ca8b-4420-ba22-a30b.jpg
Wow, that’s amazing!! I’d never have found that. Thanks so much.
 Jim
