GoZ Error - mesh has deformation shape layers
Posted By reyniers1 2 Years Ago
burkhardtdesign
burkhardtdesign
Posted 2 Years Ago
New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)
Posts: 2, Visits: 17
Hey all,I had trouble with this a couple days ago. What Worked for me was unchecking "smooth" in the GoZ settings window
Hope this helps!
paulcummins99
paulcummins99
Posted 2 Years Ago
New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)
Posts: 2, Visits: 31
Same problem - any further update?
UlrichS
UlrichS
Posted 2 Years Ago
New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)
Last Active: 5 Months Ago
Posts: 1, Visits: 8
Got the same issue any solution for a fix other than creating layers?
jehad_101778
jehad_101778
Posted 2 Years Ago
New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)
Posts: 3, Visits: 93
Yes but then you can not use GoZ and reload your new sculpted character as a character - only as a cloth what is useless and doesn't make sense. Do you know when this bug will be fixed?????
TinaT
TinaT
Posted 2 Years Ago
New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)
Posts: 16, Visits: 171
Please check if these steps resolve the issue.
1.Make sure "Match Zbrush Model Scale " is checked.https://forum.reallusion.com/uploads/images/4cfdd302-aa65-42e2-b146-c513.png
2. Re-import the model and ensure that Smt is enabled from the beginning.
https://forum.reallusion.com/uploads/images/1ea8b3e5-038c-4873-a39f-236b.png
3. Make sure Smt is enabled, then press "Divide"
4. Enter layer-recording mode, and try sculpting to test if it works.
https://forum.reallusion.com/uploads/images/6472d785-10f1-4b23-af71-8321.png
5. If sculpting works, continue to edit the mesh.
Reallusion Technical Support
email- tinateng@reallusion.com
reyniers1
reyniers1
Posted 2 Years Ago
Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)Junior Member (215 reputation)
Posts: 1, Visits: 37
Hello, using CC4 GoZ Workflow.
Been using this workflow since January this year. All character thus far have been fine and never had such an error.
For some reason now, I can't edit the mesh straight away, and when I fiddle with the Layer Recording I can eventually make changes, but the mesh remains unchanged in CC4.
Has anyone experienced a similar issue?
Thanks in advance
