Expression morph transfer to face covering?
Posted By spencerreeve 2 Years Ago
spencerreeve
spencerreeve
Posted 2 Years Ago
Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)
Posts: 6, Visits: 57
Well, I might have gotten out over my skis on this one.
 I have a character wearing a tight face covering, think a spandex super hero mask. I used Zbrush to extract the face covering from the mesh so that the topology is the same as the face. Is there a way to make it so that the mask accessory morphs to match the face expression, or is there a way for me to edit the mask for a few set expressions?
I don't know why i thought transfer weights would work. it wasn't until it got the mask made that i realized that facial expressions are basically morphs and not driven by bones.
See below for the mask  at resting and then when the character smiles.
https://forum.reallusion.com/uploads/images/b5bb8f8c-a923-48c0-9f01-45be.pnghttps://forum.reallusion.com/uploads/images/f985f6d5-a8cd-426e-9bee-4b63.png
Posted 2 Years Ago
Convert the mask to Hair > Base/all and then use Assign Conformable Regions to weight it to the face skin.
https://courses.reallusion.com/home/character-creator/hair-bread-and-eyebrow?product=Character%2520Creator&keyword=conformable&v=character-creator-4-tutorial-assigning-hair-conformable-regions
spencerreeve
spencerreeve
Posted 2 Years Ago
Working like a charm, thanks! Follow up question though, do you know why my select tool would be greyed out while doing this? i am having to go poly by poly in edit range, which is fine,https://forum.reallusion.com/uploads/images/34cca478-5ea7-45f2-acba-76d1.png but would love to make this process faster in the future.
Posted 2 Years Ago
Yes, because you checked "Smart Select".
You may either use semi-automated Smart Select or select vertices manually while Smart Select is unchecked.
