Joanne (RL)
Joanne (RL)
Posted Last Year
Visits: 4.9K
Kalex (3/14/2024) Hello,
Maybe that's a silly question, but besides supporting multi-language, is Audio2face better than Acculips for lipsync ?
Hi, If there is no Facial Mocap animation as the base perform, the mouth shape animation from A2F will be more natural/smooth than AccuLips. PS. Acculips can also use Lips Options > smooth to make the smooth animation. (requires iterative testing and adjustment)
AccuLips has the more viseme details, A2F has the smooth and easy to get talking and emotion animation, according to users' requirement to choose the solution.
adamlan
Visits: 685
liulifeng (3/14/2024) Does anyone know the reason why the software crashed at this progress?I noticed that you were opening an .usda file, I wonder did you modified the file?
Joanne (RL)
Joanne (RL)
Posted Last Year
Visits: 4.9K
liulifeng (3/14/2024) Does anyone know the reason why the software crashed at this progress? Could you please provide the captured video of the flow?
adamlan
Visits: 685
risto_986282 (3/13/2024)
I am happy for the new more simple workflow, but for some reason I do not get it to work for me. I could work with the previous one, but when I activate the autosetup it claims I should select the CC_Base_Body mesh node. I have done so. I also have tried several characters and reinstalled. But I get the same fault continuously. I would be happy to hear some ideas.  It seems you draged the a2f usd file in the scene, You can only double click the a2f usd in the content browser to open the a2f usd file then click the "Setup" button
Kalex
Visits: 6.5K
Hello,
liulifeng
liulifeng
Posted Last Year
Visits: 8
Joanne (RL)
Joanne (RL)
Posted Last Year
Visits: 4.9K
Leodegrance (3/13/2024) Just started testing this plug-in out. Looks promising. I remember over a year ago having to set up the targeting manually, which was a total pain. Now, porting the character from CC4/iClone is just one click after selecting the A2F model. I seem to recall though, that Audio2Face has a batch function to generate multiple audio files one after the other. But, in using the plugin to send the json morphs back to iClone, looks like it has to be done one file at a time. Or, am I missing something?Currently, A2F plugin does not have the function of batch loading back the Json files. I'll pass this suggestion to the development team. Thank you~
risto_986282
risto_986282
Posted Last Year
Visits: 81
I got the autosetup working. The only difference is that instead of dragging the A2F.usd -file or double clicking it, I use right mouse button and select open from the menu to open the file. Then it works. I wonder if the default is wrong or what happens, but I have repeated this with several files.
risto_986282
risto_986282
Posted Last Year
Visits: 81
I am happy for the new more simple workflow, but for some reason I do not get it to work for me. I could work with the previous one, but when I activate the autosetup it claims I should select the CC_Base_Body mesh node. I have done so. I also have tried several characters and reinstalled. But I get the same fault continuously. I would be happy to hear some ideas. EDIT: I got it solved - for me it required to use the right mouse button and select Open when opening the USD-file. Opening it by dragging it or double click did always cause this problem with several different characters.
Leodegrance
Leodegrance
Posted Last Year
Last Active: 5 days ago
Visits: 3.7K
