How to find the name of a texture
Posted By Peter_737068 3 Years Ago
Peter_737068
Peter_737068
Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)
Posts: 45, Visits: 184
That’s a shame I’ll have to figure out another way to match file names . Thanks for replying.
There are no files or names. All texture files are embedded into the object by default when you apply them.
There is a way to enable "External Texture" in Preferences, but it would take an effect next time you apply a texture to a material and the path/name would be listed below texture maps section.
Personally I would not want that as objects/projects would become dependent on a specific paths/files and if you move/delete files/folders accidentally you may invalidate a lot of assets, specially in a long run.
Peter_737068
Peter_737068
Thanks for replying. I’m not sure if that’s going to help.
I’m not trying to export the texture I just want to know what their file name is.
The reason is at the moment I only have the diffuse and bump applied, which came in automatically from imported FBX. But it’s a complex model with many materials and I need to find the corresponding roughness and metallic maps for each material and the only way I can do that is by searching for their names. If I don’t know what the diffuse texture name is then it will mean trying to eyeball 100’s of textures to figure out which one matches.
Hope that makes sense?
michaelrbarton
michaelrbarton
Posts: 974, Visits: 11.2K
You can save the highlighted textures one at a time or all in a folder. There are some icons at bottom near textures that will let you save them.
God Bless!
Peter_737068
Peter_737068
This may be a silly question but I just can't figure out how to bring up the name of a texture that is being used on a material. If I hover over the texture it brings it up larger and has the file size. I can launch the texture into photoshop but it just names it numerical value. So how do find out the name of the texture that's being referenced?
Many thanks in advance,
