Posts: 23.1K,
Visits: 36.6K
It sounds like you are not using the correct import process. You have to select Create > Accessory from the Menu Bar and you can then choose either an OBJ or FBX file. If you use this method no FBX Key will be required. For more information please click the link below. https://manual.reallusion.com/Character-Creator-4/Content/ENU/4.0/08_Cloth/Creating_Custom_Clothes_OBJ.htm
