marc.d.r.thompson (6/14/2010)
Is there any way to make a texture follow a path direction?
I currently have some lava built using the iClone water presets. The lava flows along using the wave speed setting, which moves the lava in a straight line. I'd like to be able to make the lave flow around obstacles in the the way, rather than just through them.
Cheers.
Marc.Hi Mark,
you can achieve this with an animated texture and a properly UV model. So if you have a half tube or path that bends along the lenght of it, the texture will look like it bends as well. This should be doable in sketchup, ill take a look at it tonight and see if it is possible, if it is ill post the model in skp format with the proper uvs and you can bend it any way you want and import it with 3dxchange.
Cheers,
Stuckon3d
Product Specialist
My iClone 7 gallery
My IMDB
