Does Iray support wrinkles?
Posted By DoronT770 2 Years Ago
DoronT770
DoronT770
Posted 2 Years Ago
Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)
Posts: 48, Visits: 176
Does it support it? Do I need to bake something since it seems on Iray the face is flat again
Potatopealor
Potatopealor
Posted 2 Years Ago
Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)Junior Member (107 reputation)
Posts: 5, Visits: 32
Did you ever find the answer? I'm also curious
DoronT770
DoronT770
Posted 2 Years Ago
We’ll.
I opened a ticket and they said it’s not supposed.
I tried baking it and still unsupported.
Same with sending to Omniverse.
But on unreal it works great as long as you bake all the maps (in wrinkles there’s a button to populate each of the 9 maps, 3 for each part of the face)
Potatopealor
Potatopealor
Posted 2 Years Ago
Thanks for the reply, such a shame we can't use iray.
DoronT770
DoronT770
Posted 2 Years Ago
Now I know a bit more.
As I said It doesn’t work with Omniverse.
But also with ray tracing in unreal engine.
It seems ray tracing is the problem
eljofa
eljofa
Posted 2 Years Ago
Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)
Last Active: 6 Months Ago
Posts: 76, Visits: 507
I saw on the unreal auto-update page it says this info:
Version 1.32 is compatible with Unreal Engine 5.0, 5.1. Version 1.3 above support for Expression Wrinkles with the latest RL_HQSkin shader update.
So! I assume is going to the ported to the Iray renderer soon
Cheers
Posted 2 Years Ago
eljofa (4/17/2023)
Cheers
Unfortunately there will be no further updates to the Iray Plug-in. We will however continue to upgrade the Nvidia Omniverse Connectors which also allow Iray and path tracing renders.
DoronT770
DoronT770
Posted 2 Years Ago
Well…
From what I see, he does support wrinkles until you switch to path trace.
So I’m not sure about Iray
