Character Creator 4.2, 4.21 and 4.22 Official Issues Thread
Posted By Peter (RL) 2 Years Ago
3
4
Posted 2 Years Ago
elizabethye25 (5/19/2023)
I'm still not able to export the character as fbx once it has hair and modifications - is there any other way of trying to fix that?
What does the error message say when you try to export? Perhaps you can post a screenshot showing your character and the error message. This might give a clue to the problem.
elizabethye25
elizabethye25
Posted 2 Years Ago
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Posts: 3, Visits: 10
elizabethye25
elizabethye25
Posted 2 Years Ago
Ok, great! I am using CC 4. When I load neutral base and export, it works and I can put it into other applications.
Posted 2 Years Ago
elizabethye25 (5/14/2023)
Everytime I try to export an fbx from Character Creator it fails, no matter what the settings are. I found a thread to help fix this, but it's from five years ago - do I still need to have another program to export an fbx? 3DXChange or something else?
Which version of Character Creator do you have? If you have Character Creator 4 or Character Creator 3 Pipeline then you don't need another program to export to FBX.
So if you do have CC4, open it, then choose "Load Neutral Base" from the Modify Panel. Once loaded try to export to FBX. Does this work?
elizabethye25
elizabethye25
Posted 2 Years Ago
Posted 2 Years Ago
pc2709 (5/8/2023)
Hi Peter thanks for your advise. My display resolution is  2880 x 1800. Should I change it to 1920 x 1080
Regards.
There is no need to lower the resolution if it is higher than 1920 x 1080. Normally the higher the screen resolution the more space you will have onscreen. As I mentioned previously, if you have dragged the dotted divider line between Content Manager and the Viewport as far to the left as it will go, and you still need a larger viewport, then follow the steps I provided previously to turn CM off.
One other thing to check is that your screen scaling is set to the recommended level (normally 100%). To check this, right click the Desktop and choose "Display Settings". If you find you are using a very high scaling setting (like 200%) then try lowering it to the recommended level.
pc2709
pc2709
Posted 2 Years Ago
New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)New Member (81 reputation)
Posts: 4, Visits: 103
Regards.
Posted 2 Years Ago
pc2709 (5/7/2023)
Seniors,
I am new user and learner.
I am using CC 4.22 and IClone 8.22 but in both the software I am unable to resize "Content Manager" so as to generate some space for "View Point".
Kindly help and guide.
Regards.
Hi...
What is your screen resolution? If you are using a resolution lower than 1920 x 1080 then this may be the problem of Content Manager taking up too much space.
Content Manager can be resized by dragging the dotted divider line but there is a minimum size which can't be reduced further.
An alternative is to turn off Content Manager by pressing F4 when you don't need it, or you can go to Window > Workspace > Animation which will give you the best UI layout when animating.
pc2709
pc2709
Posted 2 Years Ago
Seniors,
Regards.
Auroratrek
Auroratrek
Posted 2 Years Ago
Last Active: 3 Months Ago
Posts: 224, Visits: 1.2K
I upgraded to 4.22 and now my Morph sliders are all missing. I submitted a ticket, but wondered if anybody else had this problem. I tried reinstalling CC, and uninstalling and reinstalling the Character Pack and other morphs, which worked until I restarted CC. Anybody else have this problem, or more importantly, have a solution?? Is there any way to go back to an earlier version of CC4?
On my Youtube Channel: Quest of the Key: Chapter One
3
4
