Failed to load project message after imported reduced c3 avitar is saved in ic8 project
Posted By jimbobway 3 Years Ago
Failed to load project message after imported reduced c3 avitar is...
jimbobway
jimbobway
New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)New Member (68 reputation)
Last Active: 7 Months Ago
Posts: 3, Visits: 193
1) Import cc3 avatar created with c3 into cc4 2) export and reduce using instalLOD remesher 1024 normal and then save it to file. 3) Import aviator into ic8 4) save my project. 5) Attempt to reopen and get "failed to load project" message. I did this with a couple of different c3 avatars with the same results. I did the same thing with the default cc4 Camila avatar and there was no problem. Has anyone else had this issue? Does anyone know why this happened?Thanks!
