CC3plus Base character Render Test in Iclone 7
Posted By sungod 4 Years Ago
3
sungod
sungod
Posts: 249, Visits: 3.7K
System Win 11 , AMD 5950 Stock, GPU 2080 Super Game Drivers Default, 64GB RAM 3600MHz DDR4
Date 12-02-2022
Iclone 7.93
CC 3.44
Method CC3 DH Sample ccproject renamed to iProject and Background Hidden
Render a Talking Animation of a Dialogue using Default Microsoft Voices, NO supersampling.
576 Frames 4k Video Render AVI uncompressed.
HDD Windows WD SN850 Video output different Drive WD SN850 1TB
Result Render 576 Frames in 72 Seconds i.e. 8 Frames Per Second
This is Suppose to be a Light Test .
All Default assets.
If attachment of Project fails due to any reasons then I will provide an external link of possible.
Link
https://we.tl/t-Aw7fC9EVJu    new link
https://ufile.io/ygiw3k4b   new link
https://file.io/vNWlJX7gMMyz  maybe deleted
Edit : Kindly Take Part in this everyone who can. :)
Edit 2
Same test in MP4 in 4K
MP4 576 Frames @ 96 Seconds  so 6 Frames Per second
AVI Uncompressed 576 Frames @ 72 Seconds  so 8 Frames Per Second
Same test 1080 Render test
1080p Mp4 test 576 Frames @ 42 Seconds
1080 AVI uncompressed @ 42 Seconds
Enlighten me @all
yepkoo
yepkoo
Posts: 1.2K, Visits: 1.9K
I did sungod test and accidentally chose HDD drive first :)
It took 2 minutes 40 seconds. (160 seconds)
I then tried again with the m2 disk and it took 1 minute 10 seconds (it took 70 seconds)
However, I had to do this when there were too many programs and files open on my computer that I couldn't close.
Maybe that would save me a few more seconds.
Maybe it wouldn't save a few seconds.
As far as I understand, the maximum system resources that iClone will use while rendering are certain, and it seems to give the same result to anyone above this limit.
I also took note of the system resources it consumes while doing this process.
CPU 8%
Memory 2%
GPU 60%
DISK 7%
It doesn't seem to make any difference when you do it only with super sample 3x3.
The speed seems to be constant at about 1 second.
Windows 11 Pro , AMD RYZEN 9 3900X 3.8ghz (OC 4 ve yukarı), NVIDIA GeForce RTX 3060 Ti, 64gb ram (3400mhz), Adata XPG SX8200 Pro 1TB
sungod
sungod
@yekoo Thank you for taking part in this light test.
We had very similar results 72 vs 70 seconds with Similar Systems. Our GPU are neck to neck and 3060Ti is Few FPS better than 2080 Super so its very cool and very expected result.
I also had CC3 open while rendering.
So M2 NVME SSD is a Key factor as we can see in your benchmark.
Edit : Kindly Take Part in this everyone who can. Smile
@sundgod: I clicked your link but it says the file has been deleted.
sungod
sungod
animagic (2/12/2022)
Reuploaded in two more places
yepkoo
yepkoo
My finding is as follows.
Used 60% for GPU.
That means it uses an estimated 5GB of VRAM during rendering.
So even if you have 28 gb of vram, those with a system of 6 and above will get the same result.
So upgrading the system doesn't provide perfect performance for rendering.
But it can be important for your work scene.
I used m2 disk it used 7%.
It's a high value for an HDD, but maybe 20% for a standard SSD, maybe even lower.
So m2 disk has no advantage, a standard SSD will give the same values.
But if you render to HDD you will make the mistake of your life.
The processor and RAM do not need to be very powerful during rendering.
These are the render results of course.
The factors we mentioned are very important when working in a packed scene.
The 2 most important things you need when rendering. 6GB or above GPU and SSD
sungod
sungod
Will love to see what other people with 3090, 3080TI, 3080, and 3070 users get.
I'm currently rendering out some updated scenes of my current project so my system is tied up right now. But once there is some time I'll run the test. I have an RTX 3090.
sungod
sungod
This will help us understand what is difference with light load.
Take your time.
ckalan1
ckalan1
Posts: 276, Visits: 10.7K
I thought you might like to hear the Voice that was created using a website called Murf.ai.  MURF The lipsync was done with Acculips. There was no editing of the lips.
I rendered this with a GTX 1080 TI. I will purchase an RTX 3090 when iClone 8 is released.
Craig
Operating System
   Windows 10 Pro 64-bit
CPU
   AMD Ryzen 9
RAM
   32.0GB
Motherboard
   Gigabyte Technology Co. Ltd. X570 AORUS PRO WIFI (AM4)   49 °C
Graphics
   R240HY (1920x1080@60Hz)
   PanasonicTV0 (1920x1080@60Hz)
   3071MB NVIDIA GeForce GTX 1080 Ti (Gigabyte)   52 °C
   3071MB NVIDIA GeForce GTX 1080 Ti (EVGA)   42 °C
   SLI Disabled
Storage
   476GB Crucial_CT512MX100SSD1 (SATA (SSD))   32 °C
   931GB Crucial CT1000MX500SSD1 (SATA (SSD))
   1863GB TOSHIBA DT01ACA200 (SATA )   34 °C
   465GB Crucial CT500MX500SSD1 (SATA (SSD))
   465GB Hitachi HDP725050GLA360 (SATA )   34 °C
   5589GB Seagate Backup+ Hub BK SCSI Disk Device (USB (SATA) )   44 °C
   5589GB Seagate Backup+ Hub BK SCSI Disk Device (USB (SATA) )   46 °C
Optical Drives
   HL-DT-ST BD-RE WH16NS40
Audio
   Realtek High Definition Audio
3
