CC3 help plz
Posted By JustBad 4 Years Ago
You may find it helpful to right-click-drag images in for reference planes. That will give you the option to load the image on a plane. You can then scale and move that plane as you need. Then just delete it when you are done. You can also import multiple reference planes this way.
JustBad
JustBad
Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)Veteran Member (770 reputation)
Posts: 35, Visits: 257
So come up with something basic and replace and embed before uploading pack easy enough but we need a delete thats crazy! Thanks
Check out my work below on my Socials
YouTube
You cannot remove it unfortunately - only replace.
What you need to do, is to disable External Files in Preferences (there you could also check for external files list in current project).
Then come back and Embed background Image in Project settings.
JustBad
JustBad
When I load a background image for reference how can I remove it from the project before uploading the pack so the clients do not get this missing image error when opening the content ?
1 texture file(s) failed to load.
Please check whether the file(s) exist.
Or make sure the required codec is properly installed.
YouTube
