seperated arm
Posted By ApolloJourney 5 Years Ago
ApolloJourney
ApolloJourney
New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)
Posts: 3, Visits: 13
Hi all,
for a project I need a character in unity with a separated arm. I made a base character in CC3 and exported the mesh to Maya, There I removed part of the mesh of the underarm and made a sort of wound. Now is it possible to get this mesh back into cc3? or do I have to copy the skinning in Maya and export from there?
Hopefully there is a Guru around that can safe me some time :)
 https://forum.reallusion.com/uploads/images/8d2b1f85-c309-4e40-832e-24c4.png
vidi
vidi
Posts: 10.8K, Visits: 40.2K
When you remove or add Polygons  to a CC Character, you can this not import as CC Character back. Only as Accessory.
For to keep the CC Character Features
Instead, try to create a Morph Slider Change the Geometry of the Arm but do not delete any Polygon from the Mesh
liebe Grüße vidi
ApolloJourney
ApolloJourney
Hi Vidi,
Thnx for the reply. I will try that today, and update the status if its a good solution for me.
Danke schön :)
ApolloJourney
ApolloJourney
So, I fixed it by importing it as an accessory, than transferring the skin weights as a skin tight t-shirt. Than I hide the faces of the original mesh that where overlapping and weren't needed. And when exporting I have to make sure to select the Delete hidden mesh option.
All the functions still work, as long as i don't adjust the skin color. But for me this is fine for now.
The morph option would have been a cleaner solution, with future use in mind, but I couldn't get the objKey working when trying to create the morph object.
So since I need this to work quick in unity for a deadline, this is perfect for now.
In the future I may try to get the morph solution Vidi suggested working, but for now my problem is solved.
Danke schön @Vidi :)
