smokeyred77
smokeyred77
Visits: 9
Just did my first work through of creating a character in CC3 then going to Iclone, 3dxchange and into Unity. I added and animation and used acculips to add dialogue and added a talking motion from the body puppeteer. After that was all set up i exported that to 3Dxchange and added the animation using the 3dplus export option from Iclone. After importing the animation into unity everything works great except the audio from the animation seems to not be there. The face and body motions all work just no audio. Am I missing something or do I have to import the audio separately and just trigger it with the motion.
Posts: 23.1K,
Visits: 36.6K
Hi... Yes you will need to export the audio separately and then import that into Unity.
smokeyred77
smokeyred77
Visits: 9
Perfect, thanks for the quick response!
coach1
coach1
Last Active: 14 hours ago
Visits: 360
Peter (RL) (4/26/2021) Hi... Yes you will need to export the audio separately and then import that into Unity.How can i do that? I need the exact frames from audio and then i will have to sync it with Unity animation? Is there any official tutorial for that?
Posts: 23.1K,
Visits: 36.6K
coach1 (4/23/2022)
Peter (RL) (4/26/2021) Hi... Yes you will need to export the audio separately and then import that into Unity.How can i do that? I need the exact frames from audio and then i will have to sync it with Unity animation? Is there any official tutorial for that? Hi... You can choose WAV as the export format from the iClone Render panel.
dl_naverz_software
dl_naverz_software
Visits: 54
Hi, I'm having the same issue. I created my character using AccuLips and it works well(perfect expression and lipsync), but I cannot export audio with it. Also, I cannot find WAV as the export format from the iClone Render panel . There are only 'Export Alembic', 'Export FBX', and 'USD(Omniverse)'. Can anybody have an answer with this problem? Thanks in advance!
Posts: 23.1K,
Visits: 36.6K
dl_naverz_software (10/28/2022) Hi, I'm having the same issue.
Thanks in advance!
Hi... Just go to Render > Export Audio from the Menu Bar. Alternatively, you can select Render > Render Video and change the dropdown to wav.
dl_naverz_software
dl_naverz_software
Visits: 54
Cleared! Thanks for the prompt reply.
