Disable Lip Sync Key Auto-Generation
Posted By Ghetzi 5 Years Ago
Ghetzi
Ghetzi
Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)
Posts: 14, Visits: 94
Looked high and low and couldn't find an answer, usually means there isn't but thought I'd ask here just in case.  Is there a way to disable iClone7 from automatically generating lip sync keys?  I know you can delete them, but if you select a lot of auto-generated keys after audio import and then cut/delete, it takes a long time to remove them.  I'd rather just prevent the lip sync keys from being generated at import and start with a clean slate.  Any insight would be appreciated, thanks!
UPDATE:  Sounds like a no.  If anyone comes across this and is having the same problem, auto-generate keys will delete much faster if you don't apply smoothing to the viseme track first.  Still a slow process, but seems to work better.
Threaded View
Threaded View
Forum Post Disable Lip Sync Key Auto-Generation By Ghetzi ( 5 Years Ago )
