Disable Lip Sync Key Auto-Generation
https://forum.reallusion.com/Topic475233.aspx
Print Topic | Close Window
By Ghetzi - 5 Years Ago
Looked high and low and couldn't find an answer, usually means there isn't but thought I'd ask here just in case.  Is there a way to disable iClone7 from automatically generating lip sync keys?  I know you can delete them, but if you select a lot of auto-generated keys after audio import and then cut/delete, it takes a long time to remove them.  I'd rather just prevent the lip sync keys from being generated at import and start with a clean slate.  Any insight would be appreciated, thanks!
UPDATE:  Sounds like a no.  If anyone comes across this and is having the same problem, auto-generate keys will delete much faster if you don't apply smoothing to the viseme track first.  Still a slow process, but seems to work better.
