iClone vs Iray lighting
Posted By sonic7 6 Years Ago
sonic7
sonic7
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Posts: 1.7K, Visits: 19.4K
Greetings .....
I've imported a 'Heavy Carrier' (purchased from CG Trader) and created a fly past.
Below is a single frame from the sequence, as follows:
●1 - Screen capture showing some of the lights used
●2 - An iClone render (iClone native renderer)
●3 - An Iray render
●4 - iClone shows distinct spotlights
●5 - Iray - Spotlights are no longer distinct
Does anyone know why the *small discrete spotlights* (as seen in iClone render), are 'indistinct' with the Iray render? - It's probably something simple I'm guessing.
https://forum.reallusion.com/uploads/images/7c72bf3d-b4fc-4517-9585-6df3.png
https://forum.reallusion.com/uploads/images/8371cb4a-87c8-4a90-9428-54f3.png
https://forum.reallusion.com/uploads/images/7b407e7f-8782-4a04-984d-9cfb.png
https://forum.reallusion.com/uploads/images/349a366d-76bd-46e2-8224-0079.png
https://forum.reallusion.com/uploads/images/38fcee9d-12a9-49c8-b456-b83a.png
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :(  - yikes! ...
MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram iClone-7.93  3DXChange Pipeline 7.81  CC-3 Pipeline 3.44  Live Face  HeadShot  Brekel Pro-Body  Popcorn FX  iRAY  Kinect V2  DaVinci Resolve17  Mixcraft 8.1
I have to make breakfast, so I have to be quick, but the short answer is that in Iray you have to adjust the parameters of the spotlights, as you have in iClone.
It's been awhile since I used Iray, but there is a size parameter that will determine the sharpness of your beam. You can also load IES files I believe just as you can in iClone now. If you use those for your lights it may be easier to get similar results.
I would start wit a simple scene with a single light and see what settings in Iray you need to get the same results as in iClone.
