iClone vs Iray lighting
https://forum.reallusion.com/Topic468026.aspx
Print Topic | Close Window
By sonic7 - 6 Years Ago
Greetings .....
I've imported a 'Heavy Carrier' (purchased from CG Trader) and created a fly past.
Below is a single frame from the sequence, as follows:
●1 - Screen capture showing some of the lights used
●2 - An iClone render (iClone native renderer)
●3 - An Iray render
●4 - iClone shows distinct spotlights
●5 - Iray - Spotlights are no longer distinct
Does anyone know why the *small discrete spotlights* (as seen in iClone render), are 'indistinct' with the Iray render? - It's probably something simple I'm guessing.
https://forum.reallusion.com/uploads/images/7c72bf3d-b4fc-4517-9585-6df3.png
https://forum.reallusion.com/uploads/images/8371cb4a-87c8-4a90-9428-54f3.png
https://forum.reallusion.com/uploads/images/7b407e7f-8782-4a04-984d-9cfb.png
https://forum.reallusion.com/uploads/images/349a366d-76bd-46e2-8224-0079.png
https://forum.reallusion.com/uploads/images/38fcee9d-12a9-49c8-b456-b83a.png
By animagic - 6 Years Ago
I have to make breakfast, so I have to be quick, but the short answer is that in Iray you have to adjust the parameters of the spotlights, as you have in iClone.
It's been awhile since I used Iray, but there is a size parameter that will determine the sharpness of your beam. You can also load IES files I believe just as you can in iClone now. If you use those for your lights it may be easier to get similar results.
I would start wit a simple scene with a single light and see what settings in Iray you need to get the same results as in iClone.
