tomelissaconway
tomelissaconway
Last Active: 6 Months Ago
Visits: 3.0K
Are newer .skp files not supported in 3Dxchange?! I bought Sketchup Pro, learned how to use it, made something I specifically need for my project and then screeched to a halt when 3Dxchange refused to open the file. It took an entire month for me to do this. Workaround maybe?
0
Posts: 5.7K,
Visits: 26.5K
Load the model in SU and from the menu click on "Save as. Expand the file type window and select a SketchUp version before SU 17 - I can't remember which previous version is the last working one for 3DX, but I always use SketchUp 8. Give the file another name to keep it separate from the original one. 3DX should open the new file without problems.
tomelissaconway
tomelissaconway
Visits: 3.0K
Thank you. That "worked," but the result is a disaster.
0
toystorylab
toystorylab
Last Active: 3 days ago
Posts: 4.6K,
Visits: 29.9K
Use Pcon.Planner... Save your .skp in Sketchup and convert with few clicks to FBX/OBJ --> 3DXChange see this thread: https://forum.reallusion.com/413665/Free-Sketchy-converter-for-all-you-sketchy-peeps
tomelissaconway
tomelissaconway
Visits: 3.0K
How is pconplanner different from the .fbx/.obj files that Sketchup exports? Thanks!
0
asembakeer
asembakeer
Visits: 62
HI DEAR,
WHEN YOUR WORK IS DONE IN SKETCHUP EXPORT OR SAVE THE FILE AS ( SKETCHUP 2016 FORMAT ) - GO TO 3D EXCHANGE AND OPEN - DONE (:
matenn30
matenn30
Visits: 3.3K
In my case, I use SketchUp shop, save 3ds, operate 3dxchange7pro, and save prop. obj and fbx are difficult to adjust and are not recommended. 自分の場合、スケッチアップshopを使用し、3ds保存で、3dxchange7proで、いろいろ操作しprop保存で使用しています。objや、fbxは、調整に難しくお勧めできません。
Also, in the case of SketchUp pro, you can save it with skp.2015 or a down version around skp.2016. あと、スケッチアップのproの場合、skp.2015か、skp.2016あたりのダウンバージョンで、保存するとできます。
The forum is an amateur. フォーラムは素人です。
