Posted a set of models for this
hereCreating this to show why I made it the way I did and how it can be used. Also going to make some other different versions of how they look.
In this one there are 9 models that can be just double clicked to make the style of the building that is needed for a video I make (or anyone else who uses this).
All models can be loaded I think mostly for using it in a game engine but I also see that it would also be useful for making movies.
OK here is what I have intended for how I made it
This image just shows that iClone on my computer uses up 0.4GB of my computer resources when I load it and havent added anything to it yet
My content pack has 9 models and these images shows each of the 9 modes and how much they update my computer resources in iClone.
This one is what I made for the center area of this Monestary building that I called Cloister01. This one adds about 0.2GB to computer resources
This one is what I made to add windows to the top center area of the building. These ones are separate models so they can be added or not added to the building depending on whether they are needed or not.
I will show more on that state later. These didn't increase the GB. The must do but its small enough that it still shows the GB as 0.4.
This image shows the Doors that get added to the bottom area's of the building. Again it depends on whether they are needed or not depending on what the movie needs.
These ones increased my computer resources in iClone by 0.2GB
This image shows the Doors that can be added to the top of the building depending on whether they are needed or not for the movie its being used for.
These ones increased my computer resources in iClone by 0.1GB
This image shows the bottom internal area of the building also depending on whether they are needed or not for the movie its being used for.
This also increased my computer resources in iClone by 0.1GB
This image shows the top internal area of the building and also depends on whether it is needed or not for the movie its being used for
This one also increases my computer resources in iClone by 0.1GB
This image shows the windows I made for the top outer area of the building. Again, adding them all depends on whether they are needed or not for the movie there being used for
This one didn't increase the GB in iClone so the actual GB used are pretty low.
This image shows the walls that are on the outside area of the building. To explain what Im saying a bit better here. If no characters ever go outside the building then this model is not needed to be loaded and so it doesn't add up my computer resources by the amount this uses. That saves some for use with other things. This one is pretty small GB though but still, worthfull not to use what is not needed.....in my opinion anyway.
This image is the roof parts for the top of the building. Again, if the characters are only ever inside the building in the movie being made then this doesn't need to be loaded depending on
whether someone looks out the windows high enough that the roof gets seen.
This one adds 0.1GB to my computer resources in iClone.
OK, that shows and explains the models I made. Coming up next is some demos of things I have used so far
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
