By Delerna - 6 Years Ago
Posted a set of models for this here Creating this to show why I made it the way I did and how it can be used. Also going to make some other different versions of how they look. In this one there are 9 models that can be just double clicked to make the style of the building that is needed for a video I make (or anyone else who uses this). All models can be loaded I think mostly for using it in a game engine but I also see that it would also be useful for making movies.
OK here is what I have intended for how I made it This image just shows that iClone on my computer uses up 0.4GB of my computer resources when I load it and havent added anything to it yet
My content pack has 9 models and these images shows each of the 9 modes and how much they update my computer resources in iClone. This one is what I made for the center area of this Monestary building that I called Cloister01. This one adds about 0.2GB to computer resources
This one is what I made to add windows to the top center area of the building. These ones are separate models so they can be added or not added to the building depending on whether they are needed or not. I will show more on that state later. These didn't increase the GB. The must do but its small enough that it still shows the GB as 0.4.
This image shows the Doors that get added to the bottom area's of the building. Again it depends on whether they are needed or not depending on what the movie needs. These ones increased my computer resources in iClone by 0.2GB
This image shows the Doors that can be added to the top of the building depending on whether they are needed or not for the movie its being used for. These ones increased my computer resources in iClone by 0.1GB
This image shows the bottom internal area of the building also depending on whether they are needed or not for the movie its being used for. This also increased my computer resources in iClone by 0.1GB
This image shows the top internal area of the building and also depends on whether it is needed or not for the movie its being used for This one also increases my computer resources in iClone by 0.1GB
This image shows the windows I made for the top outer area of the building. Again, adding them all depends on whether they are needed or not for the movie there being used for This one didn't increase the GB in iClone so the actual GB used are pretty low.
This image shows the walls that are on the outside area of the building. To explain what Im saying a bit better here. If no characters ever go outside the building then this model is not needed to be loaded and so it doesn't add up my computer resources by the amount this uses. That saves some for use with other things. This one is pretty small GB though but still, worthfull not to use what is not needed.....in my opinion anyway.
This image is the roof parts for the top of the building. Again, if the characters are only ever inside the building in the movie being made then this doesn't need to be loaded depending on whether someone looks out the windows high enough that the roof gets seen. This one adds 0.1GB to my computer resources in iClone.
OK, that shows and explains the models I made. Coming up next is some demos of things I have used so far
Here are some images I used to show how I setup things depending on how I see what is needed
This one is just where people wolf around the middle area but don't go anywhere else.
This one is for where people walk around the bottom internal area of the building. I included the center because I set the windows as see through so its needed so it can be seen. Dont have the windows see through and the center parts aren't needed then. Oh and of course, when making movies inside here then beds, tables, seats etc etc for what is needed for the movie will need to be added to where they are needed inside.
This one is for where people only walk arround the internal top area. Again the windows a see through on this
Finally, this one has everything and the computer resources are only 1.2 so I think its fine having people walking arround everywhere in this Monestery Building
Here are some images that shows how the building looks Colors of many of these things can be adjusted easily by selecting the model, going into iClones Matterial list, selecting the mesh part you want to change and then using the matterial settings diffuse colors. If you can do texturing you could also send the UV reference to your 2D program and create your own images.
This image is going inside to the bottom internal area from the center area of the building
Here the character is going up to the top internal area of the building from the center area
Here the character is leaving the building through the entrance area
Here the character is looking around the internal area at the buildings central parts and can also see inside through the windows
LOL, some people might like walking around the central edge on the roof.
Here the character is walking around the portal section if the central areas
Here is a character entering from the external areas to the center area of the building
Here are some images of the bottom internal areas of the building
Now here are some images of the to inside areas of the building
Now the character is leaving the to internal area and going down the the center area
Then again, maybe he decided to turn arround and go back into the top internal areas of the building
And finally here is looking at the buiding from outside of it
more comming
new models will get showed
new models to get shown
