Animation center varies with each export of the same animation, iClone 7.71 + UE4 4.24
Posted By cesar3dartist 5 Years Ago
Animation center varies with each export of the same animation, iClone...
Procrastinator
Procrastinator
Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)
Posts: 76, Visits: 980
Not an expert with iclone but have some experience with unreal. The iclone combined animation has shifted root motion (in the beginning of the animation track). You can see the transform gizmo not at the centre bottom of the character. Try exporting simple combined animations without root movement and work out from there.
cesar3dartist
cesar3dartist
Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)
Posts: 2, Visits: 15
I have an idle pose which origin changes each time I export. The character animation does not slide inside iClone. However, inside Unreal Engine 2 different imports of such animation results in the same animation but with a different center point...blending between both make it seem as if the character is "sliding".  I didn't change the export settings of each as far as I know. The export and import settings are the same, so I'm not sure how to fix this.
https://youtu.be/HhVruLqhC40
HELP
