Instead of attaching, use "link", you can unlink at the moment you want to drop it.
A bit tricky to make the "drop" look good, make sure to set a keyframe in transform before unlinking.
Then you will have to look how fast your endkey (prop bottom) comes, maybe use "end in a bounce" transition key...
Toystorylab on Vimeo :
Crassitudes (my "Alter Ego") on Youtube:
