drop weapon help?
https://forum.reallusion.com/Topic437191.aspx
Print Topic | Close Window
By william161 - 6 Years Ago
Hello all!
how do i get a gun/prop to be unattached from a character and drop to the ground at a particular time in the timeline?...or how do I activate physics on that gun/prop when needed and make this happen in the scene?
By toystorylab - 6 Years Ago
Instead of attaching, use "link", you can unlink at the moment you want to drop it.
A bit tricky to make the "drop" look good, make sure to set a keyframe in transform before unlinking.
Then you will have to look how fast your endkey (prop bottom) comes, maybe use "end in a bounce" transition key...
By thebiz.movies - 6 Years Ago
If you want to use physics for the drop (often a more realistic motion especially for the hitting the ground part) , the manual describes how to use link and change the state of the object:
https://manual.reallusion.com/iClone_7/ENU/Content/iClone_7/Pro_7.4/20_Physics/Mixing_State_Keys_with_Linkage_Feature.htm
