Posted By Dan Miller 7 Years Ago
Last Active: 5 Months Ago
I have noticed  a similar problem, where the blend between head and neck texture is showing a clear seam. I have posted about that elsewhere.
https://forum.reallusion.com/uploads/images/63cdee68-7b24-42a5-92c9-e5da.jpg
It looks almost as if the neck is "dirtier" than the face. Unfortunately, it also seems dependent on the lighting, so if you adjust one side to match, it may not work on the other side.
This has been a long-standing issue with iClone, which was finally resolved in recent versions. So I was a bit surprised for it to reoccur again.
I haven't had time to go through the latest suggestions in this thread to see what can be done.
Dan Miller
Dan Miller
Last Active: 7 Months Ago
Posts: 374, Visits: 1.8K
So the mask in Headshot is already doing a blend. No need to do it externally. White is pure image, black is pure transparent (showing underlying skin). So varying shades of gray are varying blend levels. Notice the mask has blurred, rather than sharp edges to get a nice transition.
In the images below, I simply darkened the mask so that the white part was gray. Instant blend! :)
Sorry for the delayed reply, busy work week. So I played around with the shades of gray but was not coming up with the look I was after. I think some of the other suggestions might get me there and I will have a look at that later today. I am trying to preserve as much skin detail as possible and then distribute that to the rest of the face and areas of the neck. And while I'm at it the healing tool on blemishes of the face to make it look better.
The images show the initial result from headshot and the gray mask. The initial image before making changes looks much more realistic to me which is what I'm going for. The gray mask seems to greatly change the appearance of the character quite a lot.
I appreciate the help but today I think I should learn about the cloning tool and clean up a few nose blemishes with the healing tool.
https://forum.reallusion.com/uploads/images/c6f3a87d-4fff-41d1-8bde-a7b3.jpg
https://forum.reallusion.com/uploads/images/828beb07-e342-4159-9684-1e9d.jpg
https://forum.reallusion.com/uploads/images/048e75dd-9596-4450-a458-9308.jpg
https://forum.reallusion.com/uploads/images/3a1ac5d0-1210-42f9-b470-838a.jpg
https://forum.reallusion.com/uploads/images/aad46f95-7cab-4a79-a5bd-3bc3.jpg
Dan Miller
Dan Miller
Dorothy Jean (11/24/2019)
danmiller (11/24/2019)
I could use a tip on how to match the skin from the headshot photo with the rest of the head and body of the character. I'm using a well lit photo with diffuse lighting and the software recognizes the face with no problem. Initially I'm selecting a RTL character, Gabriel I believe with 4K texture. When I import the headshot photo, using Pro, I'm selecting body type current, and clean rough on the skin type. If I select no mask then it looks really messed up on the side of the face and head.
I attempted to edit the Base Color map in Affinity Photo by selecting an area of my skin from the front of the head and then healing around the sides of the face. This did not look very good so started over. I was thinking the skin matching was automatic but at the very least if someone can give a tip on how to match the skin that would help. Thanks.
Could you post an example of the issue you are facing?  So far I have not had any issues matching colors so please let me know so I can help! Thanks!
Here is an example but a little hard to see in this picture. If you look at the lower forehead it has the texture brought in with the headshot photo. Notice the older, rougher looking skin. Then the rest of the forehead is just smooth skin. I'm trying to figure out how to texture the whole face and neck so it looks like it belongs to the character.
https://forum.reallusion.com/uploads/images/76c49d25-e6d9-423a-a0a6-deeb.jpg
What I do is take the photo I used to create the texture and blend it with the texture from CC3. If you have some photoshop skills its pretty easy. Just use a mask.  Plus the clone tool and patch tool come in very handy as well.
If you can get a side and angle shot of the person too then you can make a really good texture. There are a ton of tutorials on youtube. Here is one!
I will need to work on my Photoshop skills. Although I do have Adobe CC, I noticed that with Photoshop 2020 I have problems opening an image. Sometimes and error, other times nothing at all. For now, and maybe for good, working with Affinity Photo.
Sounds like I will need to learn about masks, clone and patch tools. Thank you for the suggestions and the link. I will have a look at it soon. Great suggestion with the side and angle shots. That idea didn't occur to me.
Dan Miller
Dan Miller
Kelleytoons (11/24/2019)
Headshot doesn't do the neck or extend the skin beyond certain areas on the face.  For the face if there is aging using one of the "old" masks will put wrinkles and such over the entire face, which helps (nothing like that is available for the neck -- the team is aware that the neck does need some way of blending into the face and will be working on that).
For now you will need to work in your favorite editor and extend those textures -- in Photoshop the rubber stamp tool along with healing brush will help.  It's much the same as I show in that video tutorial above.  You nearly always need to do *some* editing to the diffuse and/or normals/roughness maps after they are generated, no matter the starting image.  The micro normals map will help a lot in texturing so it's worth understanding how it works and playing with it some.
Sounds good, I will learn how to use the rubber stamp tool and use the healing brush. It also sounds like I better spend some time learning about micro normals. Thank you for your suggestions. It is likely time well spent before moving on.
Dan Miller
Dan Miller
SeanMac (11/24/2019)
Hi danmiller,
May I suggest that you post the make and model of your monitor and state whether or not it has been colour calibrated?
Regards
SeanMac
Triple ASUS VS248. They are not color calibrated so I will look into that. Thank you.
Dorothy Jean
Dorothy Jean
Posts: 266, Visits: 1.1K
https://forum.reallusion.com/uploads/images/dbdccbe9-2417-45d2-b87d-7b31.jpg
Posts: 9.2K, Visits: 22.1K
Mike "ex-genius" Kelley
SeanMac
SeanMac
Posts: 416, Visits: 3.4K
Hi danmiller,
Regards
SeanMac
Dan Miller
Dan Miller
