Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
Posting an update. I got Curve Editor to work by uninstalling the Python dev patch, 7.41.26xx, and reinstalled the official release. Something in the dev version didn't work well with Curve Editor, even though newer than the official version. So now I have a curve editor I have to learn how to edit curves. Patience is not just a virtue, it goes hand in hand with perseverance. So now I have to choose which version to install, Python if I want to load Scripts, or official version if I want to edit curves. Maybe by IClone 8, which I am sure I will have to purchase an upgrade for this will be fixed.
Creator of the free website: PixelDatabase.Net A Free Online Text Based Image Editor
Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
Next weekend I will see if it works on a smaller size project. Debugging other companies products is not what I am paid for, so if it doesn't work I will just not buy it. Thanks for all the suggestions, but I have to get back to solving the problems I do get paid for.
Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
I have 32 gig of memory, and 11.1 video memory.
Last Active: Yesterday
Posts: 5.7K,
Visits: 26.5K
When an App crashes there is normally a crash dump file saved by Windows. If you have Win 10 you should be able to find the file here: C:\Users\ YOUR USER NAME\AppData\Local\CrashDumps. Be aware that these files are deleted by a Windows exit/new start so it's best to copy them to another location before doing anything else. The best thing to do in such a situation is to provide RL support with a copy of the file using the Feedback Tracker. The Dump files are normally too large to be attached to an FT post so you will need to upload it to DropBox - or any other file sharing service - and give the RL geeks a link.
SeanMac
SeanMac
Visits: 3.4K
Hi Data Juggler. Thanks for persevering. It does, as you hint, sound like a memory problem. How much standard RAM do you have? May I suggest emailing RL Tech Support whom I have always found helpful. But they do need an exact description of your hardware and what external kit you have plugged in via USB etc. Regards SeanMac Home Built in Coolermaster ATX case with GigabyteGA-Z170X-GAMING 7 MoBo, Intel i7-6700 @ 3.4 Ghz, Asus GeForce GTX 1080 TiGraphics Card, 32Gb DDR4 RAM, an Acer CB241HQK & a Samsung S24D300 monitor, Huion H610Pro Graphics Tablet, Kinect v2, Logitech C920 Webcam, Win 10 64 Bit OS Windows
Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
I tried curve editor again on new project, and it works. When I open my 'big' scene (my biggest to date anyway), Curve Editor crashes. I told them not to process my refund until I find the size limit of where it stops working, or maybe project is corrupt or something. Just posting that the plugin does launch, just not on my project with 401,000 Polygons that uses about 2.6 gig of my 11.1 gig of video memory. Back to my day job so I can afford my animation hobby; next weekend I will report if it works on other projects or not. Is there a log that IClone might right to upon crash that might reveal the cause? Thanks
Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
Thanks Chris, those are actually the scripts I was wanting, all in one place. Next, I need the lottery numbers and the directions of the stock market for the next 2 weeks. Cheers
videodv
videodv
Visits: 12.0K
You may want to have a look at these scripts as well HereChis.
SeanMac
SeanMac
Visits: 3.4K
@Data Juggler. Check my edit re Curve Editor wonderful software that allows you to put the most expressive animation onto characters. I urge you to persevere. Regards SeanMac Home Built in Coolermaster ATX case with GigabyteGA-Z170X-GAMING 7 MoBo, i7-6700 @ 3.4 Ghz, Asus GeForce GTX 1080 Ti GraphicsCard, 32Gb DDR4 RAM, an Acer CB241HQK & a Samsung S24D300 monitor, Huion H610Pro Graphics Tablet, Kinect v2, Logitech C920 Webcam, Win 10 64 Bit OS
Data Juggler
Data Juggler
Posts: 1.8K,
Visits: 5.6K
@Sean Thanks. Yes, honesty and a good work ethics go a long way.
