Problem-Import Daz Character to 3dxchange
Posted By amay0324 7 Years Ago
amay0324
amay0324
Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)Junior Member (105 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 38
After importing Daz character into 3dxchange, the character chest will not move. All other body parts articulate/stretch, however the chest is fixed in place during animation.
Unfortunately, I'm not really understanding the problem. If you have converted the Daz character to a non-standard character then you should be able to take it into iClone 7 and animate it in the normal way. For example, open Edit Motion Layer, select the Chest and rotate it as required. Are you not able to do this?
Last Active: 3 Weeks Ago
Maybe the OP means the breasts?
AncientWire
AncientWire
Posts: 62, Visits: 966
I am having this problem as well.
This is Melody for Aiko 3.  I don't know of a way to get her into CC3 since she is older than V4/M4, so I am using 3DX.
I have had this problem with a couple of other figures.
I have tried changing the bones around, but nothing seems to be working for Melody.
If I use the DAZ Preset, I get the green ball in the upper left, but the convert button won't light up.
If I try moving the bones around I get a red ball in the upper left, and the convert button won't light up.
Melody A3 torso problem.JPG (204 views, 34.00 KB)
Skuzzlebutt
Skuzzlebutt
Posts: 582, Visits: 8.6K
the charactorization isnt correct
its happened before due to some updates
re-charactorize the model,
test with animations provided
and save the profile for future conversions
If you post a picture of your bone choices in the Characterization panel, we can probably spot what went wrong. Most likely culprit is you skipped over bones in the torso sub-panel (where the collar bones are.
Make sure you always work your way up from the bottom until all torso bones are characterized.
https://forum.reallusion.com/uploads/images/fbed7eb5-a0da-4861-ac46-e2a1.jpg
AncientWire
AncientWire
Thank you.
The DAZ spine defaulted to using one up from the bottom and I tried a bunch of things and couldn't clear it.
I just started over and remapped all of the bones, saved my new custom setting, applied to iClone it it works great!
