ultimativity
ultimativity
Last Active: 8 Months Ago
Visits: 737
Hello,
I am searching for a way to increase the font size for the CC3 interface. I do not see it in Preferences.
Thanks,
Nathan
Nathan
Posts: 23.1K,
Visits: 36.6K
Hi Nathan Character Creator 3 supports 4K and other Ultra HD screens but doesn't offer a user changeable icon and font size unfortunately.
Posts: 5.7K,
Visits: 26.5K
Peter (RL) (12/18/2018)
And this unfortunate oversight is expected to be corrected when? :blink::Whistling::ermm:
Posts: 23.1K,
Visits: 36.6K
wires (12/18/2018)
And this unfortunate oversight is expected to be corrected when? :blink::Whistling::ermm: It's not an oversight. CC3 automatically detects the screen resolution and adjusts accordingly so it supports SD, HD and 4K Ultra HD.
ultimativity
ultimativity
Visits: 737
Thanks very much for the response. Appreciate it.
Nathan
alienorbit
alienorbit
Visits: 9
The issue is, that on many 4k screens, the UI is unusable, because the fonts and icons aren't scaled appropriately to match the pixel density. Are there any plans to address this still serious issue?
Visits: 31.4K
alienorbit (3/12/2019) The issue is, that on many 4k screens, the UI is unusable, because the fonts and icons aren't scaled appropriately to match the pixel density. Are there any plans to address this still serious issue?It works for my 4k 43" screen. All depends on your screen size.
connor.fabiano
connor.fabiano
Last Active: 7 Years Ago
Visits: 3
I downloaded the software to test it out and I was planning on buying it because it looked awesome, but I can't read any of the text in the application. I understand if it works fine for people with particular set ups, but I side with "wires" and I find it to be an oversight. If the company is not concerned about attracting amateurs and semi-pros then it isn't an issue, otherwise I echo the suggestion to allow font size to be adjusted. I can only speak for myself and as a potential customer I cannot use the software.
Posts: 23.1K,
Visits: 36.6K
connor.fabiano (7/15/2019) I downloaded the software to test it out and I was planning on buying it because it looked awesome, but I can't read any of the text in the application. I understand if it works fine for people with particular set ups, but I side with "wires" and I find it to be an oversight. If the company is not concerned about attracting amateurs and semi-pros then it isn't an issue, otherwise I echo the suggestion to allow font size to be adjusted. I can only speak for myself and as a potential customer I cannot use the software.Hi... Are you using the recommended scaling settings on your computer? Normally the recommended settings should allow CC3 to display correctly on a 4K screen (but you can up it to see if it helps). You can check your scaling by right-clicking the Desktop and choose Display Settings. I will also pass on your feedback to the Character Creator team for review. :)
solarmanJc
solarmanJc
Visits: 142
will it must not be working ..you might want to check it out ... My CC3 is so big on my screen I am unable to us CC3 time to get my money back
