Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character Replacement problem
Posted By gvraju.666 7 Years Ago
Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character...
gvraju.666
gvraju.666
Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)
Posts: 16, Visits: 65
1 =
Hey so i'm new to crazy talk animator 3 and i'm trying to make a custom G2 character. For some reason in the sprite editor I cant replace the sprites for different angles. First i put the template G2 dummy character in stage and then switch to composer mode.I then click on left forearm and sprite editor button to change it success.
https://forum.reallusion.com/uploads/images/21753add-fd13-4b58-a10c-86b0.jpg
 When i open the it in stage mode 270  it is not visible to me.in  other angles also it get same problem -
https://forum.reallusion.com/uploads/images/17fb8410-6c68-4738-980e-7ec6.jpg
again tried to fix the sprite replacement run time composer..
https://forum.reallusion.com/uploads/images/736d9c39-8556-490f-b6ad-e970.jpg
then i open the composer mode it visible..when i mirror it at right side
https://forum.reallusion.com/uploads/images/033ebe04-dbd1-4b1f-a0e0-ee40.jpg
again in stage mode
https://forum.reallusion.com/uploads/images/3a52dbdd-a371-40ae-b043-3e11.jpg
and test it in stage mode with 2d motion key editor the sprits of other side is not visible
pls tell us the right way to  how to add sprits in different angle  0-45-90-135-180-225-270-315-
we already seen the tutorial of basic character creation -with sprite replacement in 0 angle.. we need 45 and 270 angled base tutorial ...
in crazytalk animator 3 ...
And with flash white paper Pipeline_Template_and_Tools
Threaded View
Threaded View
Forum Post Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character... By gvraju.666 ( 7 Years Ago )
Forum Post After you edit a character in Composer Mode and return to the stage it... By jlittle ( 7 Years Ago )
Forum Post sir we r not able to get the YouTube tutorial the sprite using the... By gvraju.666 ( 7 Years Ago )
Forum Post hello sir we tried to replace as u said before - " replace... By gvraju.666 ( 7 Years Ago )
Forum Post Here is a short video showing step by step G2 character sprite... By jlittle ( 7 Years Ago )
Forum Post HELLO SIR THANK U FOR SEND VIDEO TO US .WE TRIED IT ..PLS SEE THIS... By gvraju.666 ( 7 Years Ago )
Forum Post Do the sprite replacement on the character. Save the character from... By jlittle ( 7 Years Ago )
Forum Post HELLO SIR WE DON AS U SAID ..SEE ONCE RAR FILE AND PIC AND... By gvraju.666 ( 7 Years Ago )
Forum Post Ok, I see the issue now. What the problem is, is that the Fore Arm is... By jlittle ( 7 Years Ago )
Forum Post hello sir thank u sir .. sir we need help that in your tutorials... By gvraju.666 ( 7 Years Ago )
Forum Post You can create individual .png images for each sprite and angle and... By jlittle ( 7 Years Ago )
Forum Post HELLO SIR THANK U LAST 6 DAY S AGO U HAVE GIVEN A ANSWER FOR... By gvraju.666 ( 7 Years Ago )
Forum Post Without using/opening a copy of your character I would guess that the... By jlittle ( 7 Years Ago )
Forum Post hello sir thank u sir we r not getting this pls send a video file to... By gvraju.666 ( 7 Years Ago )
Forum Post sir we r getting mirror problem sir in 270 when add a sprite to left... By gvraju.666 ( 7 Years Ago )
Forum Post CRAZY TALK ANIMATOR G2 DUMMY CHARACTER 270 ANGLE MIRROR SPRITE... By gvraju.666 ( 7 Years Ago )
Forum Post crazy talk animator 3.3.3007.1 mirror problem in 270 angle as we... By gvraju.666 ( 7 Years Ago )
Forum Post Attach the character with the issue here and I will look at it. Jeff... By jlittle ( 7 Years Ago )
Forum Post sir the the problem in 270 angle mirror issue it is not... By gvraju.666 ( 7 Years Ago )
Forum Post Go to your profile page. On the left at the bottom there is a section... By jlittle ( 7 Years Ago )
Forum Post Hello sir the the problem in 270 angle mirror issue is not... By gvraju.666 ( 7 Years Ago )
Forum Post Ok, I see the problem now! You are trying to mirror the right side to... By jlittle ( 7 Years Ago )
Forum Post hello sir thank for replay ..sir we r using only vectors sir... By gvraju.666 ( 7 Years Ago )
Forum Post Ok, here is the issue: To use the Mirror function in Composer Mode you... By jlittle ( 7 Years Ago )
Forum Post hello sir we request u sir pls give us a video tutorial for rigging... By gvraju.666 ( 6 Years Ago )
Forum Post hello sir we had a problem in 270 gs sprite replacement ....pls give... By gvraju.666 ( 6 Years Ago )
Forum Post Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character. we are... By agastyamedia2018 ( 6 Years Ago )
