FAITH BASED GAMES
FAITH BASED GAMES
Visits: 57
Posts: 9.2K,
Visits: 22.1K
First things first - the search works, although sometimes (like almost everything on this forum) you need to be patient and sometimes even hit it more than once. Hitting the advanced search is even better, because as a rule it's very slow on broader ones. The first question is most likely the mesh has gotten hidden by default, but you can hide/unhide it by going to the Mesh Modifier tab, choosing Edit Mesh Mode, and then selecting what you want and either Show or Hide it. I have no idea about UE.
FAITH BASED GAMES
FAITH BASED GAMES
Visits: 57
Hey Kelleytoons! Wow thanks for that quick reply! I'll give that search trick a little more time next time...guess I am used to click an look....the optimum word is patience! ;)
As for the mesh problem...yes I have tried that but a no go with that... :(
I can get the middle part to show up, as you can see in the 2nd screen shot, but not the cleavage area. I'll do that search here (with patience ... ;) ) and hopefully find it there...I even did a Google and YouTube search but still nothing. Thanks for the help. ~maimas :)
**************************** FAITH BASED GAMES
Posts: 9.2K,
Visits: 22.1K
If you don't get this working and no one else helps I'll look at it tomorrow (cold meds are now putting me to sleep)
FAITH BASED GAMES
FAITH BASED GAMES
Visits: 57
Ok that would be GREAT! Thanks Kelleytoons! ;)
Also I have been very patient and the search still hasn't worked and I have even hit the search probably 25 times...nothing :(
Last Active: 2 Weeks Ago
Posts: 5.3K,
Visits: 16.8K
1. Try to set Shadow to "Receive Only" for the Camisole  2. Cannot be sure, but it looks as if you still have a hidden mesh there for that particular character. Do what KT says, or go to Windows > Cloth Layer Settings > Reset Content Settings 3. The way I see it, "search" does not work properly here at the forum. It works while searching for a single keyword, or multiple keywords with "OR" operator (Any Keywords). But the most important search for "All Keywords" simply does not work. I already reported it, but nothing has been done.
Posts: 9.2K,
Visits: 22.1K
The "all keywords" search works fine for me -- just did it now (perhaps it's browser related -- I use Chrome).
Posts: 5.3K,
Visits: 16.8K
Kelleytoons (12/16/2017) The "all keywords" search works fine for me -- just did it now (perhaps it's browser related -- I use Chrome).
I tried all sorts of browsers. Same result... OK. Lets experiment. Your quoted post contains 2 keywords "browser" and "Chrome". I should be able to locate it by entering those keywords and do an Advanced Search with All Keywords. Right? Here is a screenshot of the query result:  Do you have it different?
Posts: 9.2K,
Visits: 22.1K
Hmmm, it's odd because it does seem to work in the titles, just not in the message body (which is why I probably thought it was working in both places). And I could have sworn it worked before -- but perhaps I was either fooled by the titles again. Did you ever get a response from RL?
Posts: 5.3K,
Visits: 16.8K
Well, it does not work for the title either. It does work as "Any Keywords", that is how the basic search at the top is set to work. But you understand, the search with "OR" would bring a whole bunch of unrelated to the specified "keywords" posts. Specially if one of the keywords is very "general". It is impossible to find related information that way. I did not actually apply to RL with this directly. Just posted this about 3 month ago: https://forum.reallusion.com/FindPost341775.aspxI guess it was missed or neglected. Or worse yet, "All keywords" was intentionally turned off as it normally is more resource intense search type than any other. Update: I forgot. There is workaround with google site search. Use: site:forum.reallusion.com your keywords But it only as good as the site is optimized for SE crawl. This one for instance, with misspelled keyword would find a post by Kungphu (nothing personal :)): site:forum.reallusion.com Zbrush workround DAZ
