iClone 4.12 Update - Now Available
Posted By Peter (RL) 17 Years Ago
Posted 17 Years Ago
You can update via LiveUpdate or find out more by going to the link below.
http://www.reallusion.com/iclone/iclone_upgrade.asp
v4.12 (4.12.1313.1) released 14 January-10
  • Fixed: Some iProp animation cannot be removed when clicking the “Reset” button.
  • Fixed: Fail to remove the video when a project has lost its video file link.
  • Fixed: iClone3 avatars with a particle attached cannot be loaded.
  • Fixed: The color of the prop would also be changed when adjusting the skin color of a non-human character with the prop attached.
  • Fixed: A project containing the object with incorrect AML data cannot be loaded.
v4.11 (4.11.1218.1) released 21 December-09
  • Fixed: Bug that caused low quality when break 8 bit audio clip
  • Fixed: Failure to produce HTML page in Flash output when checked “Produce HTML Page”.
  • Fixed: Failure to download content from Backstage while UAC (User Account Control) was activated under Windows Vista and Windows 7.
  • Fixed: Loading error of iClone2 Projects which caused loss of "Tree", "Grass", "CTS", "SoundFX" and "Music" in certain condition.
  • Fixed: Bug that caused “Smooth” tool in “Adjust the facial texture” panel that crashed iClone
  • Fixed: Bug that caused Failure to load .iScene with numerous Trees.
  • Fixed: Bug that caused DRM contents failing to be recognized.
v4.1 (4.1.1125.1) released 26 November-09
  • Added: Context menu to load image or video files as plane, image layer, billboard or background when using the right mouse button to drag & drop image or video files into the program.
  • Added: "Drag & Drag Automatic External Files" option in Preferences to always load files as external sources when using drag & drop from windows.
  • Added: The audio volume of a video is now keyable and can be used to create fade in and fade out effects using the timeline track.
  • Added: Option to "Replace" a video texture from "Set > Video".
  • Added: Option to 'Lock ratio' when manually adjusting the resolution on the export pages.
  • Added: Embedded characters now have footstep sounds.
  • Enhanced: DRM content that has already been verified will work even when the file path is changed.
  • Enhanced: Stability of the 1-Click Content Verification function.
  • Enhanced: Capability to Drag & Drop .vns files into iClone.
  • Enhanced: Hand quality of embedded characters.
  • Fixed: Drag & Drop would not work when UAC was set to 'on' under Windows Vista and Windows 7
  • Fixed: IK would not work with non-human characters sometimes.
  • Fixed: Changing a character's display method to 'Bounding Mesh' using the right-click menu would cause the program to crash.
  • Fixed: The '2-Sided' check box in the 'Adjust the Facial Texture' menu would not work.
  • Fixed: Moving along a path would not work properly if the path was projected to the terrain.
  • Fixed: McAfee anti-virus would cause avatars to load very slowly.
  • Fixed: An obvious line would appear between a character's head and neck when a new face is created or the face was changed.
stuckon3d
stuckon3d
Posted 17 Years Ago
Posts: 1.8K, Visits: 7.8K
Hi Peter,
someone in the forum found a bug on the preview cam, you guys should be able to fix this quick.
The bug is that when you are in preview cam mode, it allows you to key frame the "reset" button as well as "move and rotate". These functions should not be key able for the preview cam because there is no time display to fix the problem. So either remove the keying function or allow us to view these parameters on the timeline so that we can erase the keys if we want to.
Thank you for listening,
Stuckon3d
Product Specialist
My iClone 7 gallery
My IMDB
Posted 17 Years Ago
Hi SO3D.. The iClone team will be looking into this issue. Thanks for the feedback.
Edward (RL)
Edward (RL)
Posted 17 Years Ago
Posts: 301, Visits: 4.9K
Ah... it is a bug really :D
Before the bug be fixed, you could press "F" to back your preview cam to normal and continue your editing
aknzrdude
aknzrdude
Posted 16 Years Ago
Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)
Posts: 2.1K, Visits: 11.0K
it looks like update 4.11 broke another thing - when 4.02 came iout it solved my loading of iclone 3 projects, with 4.11 the problem looks like it's back!
getting "Failed to load the file..." error on protects with clone bone characters
Mick
Mick
Posted 16 Years Ago
Last Active: 16 Years Ago
Posts: 218, Visits: 588
aknzrdude (1/2/2010)
Hi Gabe,
Because we cannot repeat your issue, we would be grateful if you could provide your project file to us. You may attached it in this ticket. If the size is too large, please send the file to our Gmail: reallusion@gmail.com. After uploading, please inform me.
We apologise for the inconvenience caused.
Yours sincerely,
Mick
Technical Support
Reallusion Inc.
aknzrdude
aknzrdude
Posted 16 Years Ago
hi mick i just sent the project file
aknzrdude
aknzrdude
Posted 16 Years Ago
one more nit - in th past (ver 3 or 4.0) - i can add folders and items in that folder via windows explorer and they will show up on iclone content manager (custom tab) now they don't automatically appear - i have to import them adding an additional layer of work
aknzrdude
aknzrdude
Posted 16 Years Ago
one more problem -
launch iclone, click on stage, select image layer - i clone 4.11 crashes
launch iclone, open previous project, click on stage, select image layer - i clone 4.11 crashes
Posted 16 Years Ago
Hi Gabe,
Sorry to hear about the problems you experiencing since the 4.11 update.
All of the issues you have mentioned seem to be system specific and not ones I 'am experiencing or can reproduce myself. As Mick has already stated, they will look into these issues so hopefully a fix can be found soon for you.
