iClone 4.12 Update - Now Available
Posted By Peter (RL) 17 Years Ago
Posted 17 Years Ago
Posts: 23.1K, Visits: 36.6K
You can update via LiveUpdate or find out more by going to the link below.
http://www.reallusion.com/iclone/iclone_upgrade.asp
v4.12 (4.12.1313.1) released 14 January-10
  • Fixed: Some iProp animation cannot be removed when clicking the “Reset” button.
  • Fixed: Fail to remove the video when a project has lost its video file link.
  • Fixed: iClone3 avatars with a particle attached cannot be loaded.
  • Fixed: The color of the prop would also be changed when adjusting the skin color of a non-human character with the prop attached.
  • Fixed: A project containing the object with incorrect AML data cannot be loaded.
v4.11 (4.11.1218.1) released 21 December-09
  • Fixed: Bug that caused low quality when break 8 bit audio clip
  • Fixed: Failure to produce HTML page in Flash output when checked “Produce HTML Page”.
  • Fixed: Failure to download content from Backstage while UAC (User Account Control) was activated under Windows Vista and Windows 7.
  • Fixed: Loading error of iClone2 Projects which caused loss of "Tree", "Grass", "CTS", "SoundFX" and "Music" in certain condition.
  • Fixed: Bug that caused “Smooth” tool in “Adjust the facial texture” panel that crashed iClone
  • Fixed: Bug that caused Failure to load .iScene with numerous Trees.
  • Fixed: Bug that caused DRM contents failing to be recognized.
v4.1 (4.1.1125.1) released 26 November-09
  • Added: Context menu to load image or video files as plane, image layer, billboard or background when using the right mouse button to drag & drop image or video files into the program.
  • Added: "Drag & Drag Automatic External Files" option in Preferences to always load files as external sources when using drag & drop from windows.
  • Added: The audio volume of a video is now keyable and can be used to create fade in and fade out effects using the timeline track.
  • Added: Option to "Replace" a video texture from "Set > Video".
  • Added: Option to 'Lock ratio' when manually adjusting the resolution on the export pages.
  • Added: Embedded characters now have footstep sounds.
  • Enhanced: DRM content that has already been verified will work even when the file path is changed.
  • Enhanced: Stability of the 1-Click Content Verification function.
  • Enhanced: Capability to Drag & Drop .vns files into iClone.
  • Enhanced: Hand quality of embedded characters.
  • Fixed: Drag & Drop would not work when UAC was set to 'on' under Windows Vista and Windows 7
  • Fixed: IK would not work with non-human characters sometimes.
  • Fixed: Changing a character's display method to 'Bounding Mesh' using the right-click menu would cause the program to crash.
  • Fixed: The '2-Sided' check box in the 'Adjust the Facial Texture' menu would not work.
  • Fixed: Moving along a path would not work properly if the path was projected to the terrain.
  • Fixed: McAfee anti-virus would cause avatars to load very slowly.
  • Fixed: An obvious line would appear between a character's head and neck when a new face is created or the face was changed.
Threaded View
Threaded View
Forum Post iClone 4.12 Update - Now Available By Peter (RL) ( 17 Years Ago )
Forum Post Hi Peter, someone in the forum found a bug on the preview cam, you... By stuckon3d ( 17 Years Ago )
Forum Post Hi SO3D.. The iClone team will be looking into this issue. Thanks for... By Peter (RL) ( 17 Years Ago )
Forum Post Ah... it is a bug really :D Before the bug be fixed, you could press... By Edward (RL) ( 17 Years Ago )
Forum Post it looks like update 4.11 broke another thing - when 4.02 came iout it... By aknzrdude ( 16 Years Ago )
Forum Post [quote][b]aknzrdude (1/2/2010)[/b][hr]it looks like update 4.11 broke... By Mick ( 16 Years Ago )
Forum Post hi mick i just sent the project file By aknzrdude ( 16 Years Ago )
Forum Post one more nit - in th past (ver 3 or 4.0) - i can add folders and items... By aknzrdude ( 16 Years Ago )
Forum Post one more problem - launch iclone, click on stage, select image layer... By aknzrdude ( 16 Years Ago )
Forum Post Hi Gabe, Sorry to hear about the problems you experiencing since the... By Peter (RL) ( 16 Years Ago )
Forum Post Hi Gabe, Your project has been passed to our developing team. We will... By Mick ( 16 Years Ago )
Forum Post hi mick image layer crashes without any projects loaded launch... By aknzrdude ( 16 Years Ago )
Forum Post [quote][b]aknzrdude (1/5/2010)[/b][hr]hi mick image layer crashes... By gizmo ( 16 Years Ago )
Forum Post Hi Gabe and Gizmo, About the crash issue, I've passed this situation... By Mick ( 16 Years Ago )
Forum Post To Gabe, About your project loading issue, we found that this project... By Mick ( 16 Years Ago )
Forum Post Yes, sorry Mick . . . I did indeed mean C127_Terrain_Beach. Must have... By gizmo ( 16 Years Ago )
Forum Post I have DLd the 4.11 patch 3 times - each time I get as far as the EULA... By franni ( 16 Years Ago )
Forum Post [quote][b]franni (1/7/2010)[/b][hr]I have DLd the 4.11 patch 3 times -... By Peter (RL) ( 16 Years Ago )
Forum Post v4.12 (4.12.1313.1) released 14 January-10 You can get the new... By Peter (RL) ( 16 Years Ago )
Forum Post peter i am getting a page not found error By aknzrdude ( 16 Years Ago )
Forum Post Did you try installing as Administor? Right-click the patch file and... By animagic ( 16 Years Ago )
Forum Post Thanks for the "Run as administrator" tip but it's exactly the same... By franni ( 16 Years Ago )
Forum Post The posted link points to the 4.11 patch. Try this:... By animagic ( 16 Years Ago )
Forum Post Its not a bug ! Its a design feature:D By bluemidget666 ( 16 Years Ago )
Forum Post Can someone please take a minute and describe the improvements offered... By Paumanok West ( 16 Years Ago )
Forum Post I just tried to install the patch and got the following message: By wires ( 16 Years Ago )
Forum Post Regarding my last post, Live Update solved the problem. [quote]Can... By wires ( 16 Years Ago )
Forum Post Hey RL, Thanks so much for continually issuing bug fixes. I can't... By Paumanok West ( 16 Years Ago )
Forum Post [quote][b]Paumanok West (1/14/2010)[/b][hr]Hey RL, Thanks so much for... By charles_avanti ( 16 Years Ago )
Forum Post Peter Do we need to download all the patches or can we just dwnload... By Corvega ( 16 Years Ago )
Forum Post [quote][b]setroc2 (1/18/2010)[/b][hr]Peter Do we need to download all... By animagic ( 16 Years Ago )
Forum Post oops What if you don't apply the 4.1 patch first? (is that why I... By markofkane ( 16 Years Ago )
