Lip options disabled ?
Posted By Delta_Webb 9 Years Ago
Delta_Webb
Delta_Webb
Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)
Posts: 7, Visits: 77
Dear all,
I have very recently discovered (post curve editor patch as I haven't used lip options since then) that now when I right click on an audiofile in my timeline, the button "lip options" is greyed and unusable.
It was very handy to change the power or the smoothness of a particular track.
Is this a bug ?
Is this intended ?
Is there a workaround ?
Any one faces the same issue ?
I can put a TTS or put an audio file it does not change anything, this options has been deactivated.
For the record I am using this on a CC character.
Best,
I tried this with one of the included CC characters and for me the Lip Options are enabled.
https://forum.reallusion.com/uploads/images/854e759f-1586-49c2-abfa-d6a6.png
I expanded the Viseme track and then get the Lip Options as one of the sub-tracks. Right-click and select Lip Options to bring up the Lip Options dialog.
I tested this with a built-in TTS voice, but it should also work for audio files. Interestingly, the TTS version now assigns correct visemes (it used to do that only in CT I believe).
Delta_Webb
Delta_Webb
Fantastic, we use to have the lip options straight from right clicking on the audio track (which is no longer the case), I didn't see this new sub option within the viseme track to get to it.
Problem solved it works fine ! Thanks a lot buddy !
