By Delta_Webb - 9 Years Ago
Dear all,
I have very recently discovered (post curve editor patch as I haven't used lip options since then) that now when I right click on an audiofile in my timeline, the button "lip options" is greyed and unusable.
It was very handy to change the power or the smoothness of a particular track.
Is this a bug ? Is this intended ? Is there a workaround ? Any one faces the same issue ?
I can put a TTS or put an audio file it does not change anything, this options has been deactivated.
For the record I am using this on a CC character.
Best,
By animagic - 9 Years Ago
I tried this with one of the included CC characters and for me the Lip Options are enabled.
I expanded the Viseme track and then get the Lip Options as one of the sub-tracks. Right-click and select Lip Options to bring up the Lip Options dialog.
I tested this with a built-in TTS voice, but it should also work for audio files. Interestingly, the TTS version now assigns correct visemes (it used to do that only in CT I believe).
Fantastic, we use to have the lip options straight from right clicking on the audio track (which is no longer the case), I didn't see this new sub option within the viseme track to get to it. Problem solved it works fine ! Thanks a lot buddy !
