Posts: 23.1K,
Visits: 36.6K
lpxgroupgames (8/22/2018)
Hi Peter How many times can I pass the iclone maximum license to between computers? or it is unlimited.
If you remember to uninstall from old computers while connected to the internet, then you do so unlimited times. If you have to manually deactivate because of hardware issues, then you can do this 10 times. However it is unlikely you will have hardware issues 10 times during the life of a particular product version, but if you do you can still contact Customer Support for help.
ThayuGames
ThayuGames
Visits: 9
[cita] [b] Peter (RL) (9/7/2017) [/ b]
También puede desactivar una computadora desde su cuenta de miembro si tiene problemas de hardware y no puede desinstalar.
El proceso es el siguiente:
1. Inicie sesión en su cuenta de miembro. 2. Pase a la página de Registro. 3. Verifique la columna "Número Activado". Si sus productos muestran 2, debe desactivar antes de poder volver a instalar. 4. Haga clic en el enlace "Detalles" en la columna Número Activado. 5. Desplácese hacia abajo para ver las computadoras actualmente activadas. 6. Haga clic en el enlace "Desactivar ahora" para eliminar una computadora. 7. Ahora debería poder instalar nuevamente en una computadora nueva. Espero que esto ayude.
[/citar]
dogged2003
dogged2003
Visits: 4.5K
Only 10 time's. Then bay new license.
My YouTube channel.
Posts: 23.1K,
Visits: 36.6K
You can also deactivate a computer from your Member Account if you have hardware issues and can't uninstall.
The process is as follows:
1. Login to your Member Account. 2. Switch to the Registration page. 3. Check the "Activated Number" column. If your products show 2 then you need to deactivate before you can install again. 4. Click the "Details" link in the Activated Number column. 5. Scroll down to see the computers currently activated. 6. Click the "Deactivate Now" link to remove a computer. 7. You should now be able to install again on a new computer. I hope this helps.
TheOldBuffer
TheOldBuffer
Visits: 6.4K
You must uninstall the software (while online) then it can be installed on another computer.
Homebuilt computer - Windoze 10, INTEL i9 9900 k @ 5.1 GHz, EVGA RTX 2080 TI XC ULTRA, 16GB 3100 MHz RAM, Asus Maximus Hero XI motherboard, Sound blaster Z series. iClone6 & 7 Pipeline, Crazytalk 8, Crazytalk Animator 2, Facefilter, Pop video 3, Hitfilm 4Pro, Cubase 8.5 Pro,
monika.igl
monika.igl
Last Active: 8 Years Ago
Visits: 2
Hi, I´d like to buy the complete version (CrazyTalk Animator 3 Pipeline Bundle). My question ist: If i will change my computer in future (because i have a new one or whatever) is it a problem to change the license to any other computer/laptop etc. o r if not, what do I have to consider..? Thanks a lot!
