Transfer of License from one computer to another
https://forum.reallusion.com/Topic339994.aspx
Print Topic | Close Window
By monika.igl - 9 Years Ago
Hi,
I´d like to buy the complete version (CrazyTalk Animator 3 Pipeline Bundle).
My question ist: If i will change my computer in future (because i have a new one or whatever) is it a problem to change the license to any other computer/laptop etc. o
r if not, what do I have to consider..? Thanks a lot!
By TheOldBuffer - 9 Years Ago
You must uninstall the software (while online) then it can be installed on another computer.
By Peter (RL) - 9 Years Ago
You can also deactivate a computer from your Member Account if you have hardware issues and can't uninstall.
The process is as follows:
1. Login to your Member Account.
2. Switch to the Registration page.
3. Check the "Activated Number" column. If your products show 2 then you need to deactivate before you can install again.
4. Click the "Details" link in the Activated Number column.
5. Scroll down to see the computers currently activated.
6. Click the "Deactivate Now" link to remove a computer.
7. You should now be able to install again on a new computer.
I hope this helps.
By dogged2003 - 9 Years Ago
Only 10 time's. Then bay new license.
By ThayuGames - 8 Years Ago
Hi Peter
How many times can I pass the iclone maximum license to between computers? or it is unlimited.
[cita] [b] Peter (RL) (9/7/2017) [/ b]
También puede desactivar una computadora desde su cuenta de miembro si tiene problemas de hardware y no puede desinstalar.
El proceso es el siguiente:
1. Inicie sesión en su cuenta de miembro.
2. Pase a la página de Registro.
3. Verifique la columna "Número Activado". Si sus productos muestran 2, debe desactivar antes de poder volver a instalar.
4. Haga clic en el enlace "Detalles" en la columna Número Activado.
5. Desplácese hacia abajo para ver las computadoras actualmente activadas.
6. Haga clic en el enlace "Desactivar ahora" para eliminar una computadora.
7. Ahora debería poder instalar nuevamente en una computadora nueva.
Espero que esto ayude.
[/citar]
By Peter (RL) - 8 Years Ago
lpxgroupgames (8/22/2018)
Hi Peter
If you remember to uninstall from old computers while connected to the internet, then you do so unlimited times.
If you have to manually deactivate because of hardware issues, then you can do this 10 times.
However it is unlikely you will have hardware issues 10 times during the life of a particular product version, but if you do you can still contact Customer Support for help.
