Grace (RL)
Grace (RL)
Last Active: 2 Weeks Ago
Visits: 5.1K
Curve Editor 05: Outliner Intro
Grace (RL)
Grace (RL)
Visits: 5.1K
Tree / List View- When an Avatar is selected, the default Outliner display mode is List View.
- When a Prop is selected, the default Outliner display mode is Tree View.
- You can switch between the display modes at any moment.
Grace (RL)
Grace (RL)
Visits: 5.1K
Color CodingCurve Editor’s color coding is the same as the gizmo’s XYZ axis:
Grace (RL)
Grace (RL)
Visits: 5.1K
Relations between Outliner and the Graph View
Grace (RL)
Grace (RL)
Visits: 5.1K
Selection Visibility
Specification: - Ctrl+dragging on the components of the Outliner will select several components at once.
- Ctrl+click on a single component to add it to the selection list and do it again to take out out of the selection list.
- Shift+click to select an entire range of components.
- Selected components are not restricted to single bones or groups. Disparate selections can span across the entire list and anything selected will show up in the Graph Editor.
