HACK YOU DISPLAY AND GET BETTER QUALITY OUTPUT IN ICLONE 7
Posted By wildstar 8 Years Ago
Rated 4.2 stars based on 5 votes.
3
4
wildstar (1/4/2019)
Alasandro (1/3/2019)
Can anyone tell me if this hack is still valid. Does it still have the same affect for the most recent Iclone Version 7.4?
this bug was corrected. i want to ask to admins to delete this post .
I am not sure why you are insisting that it was fixed, when it was not. Not sure about DOF, but I still get whole lot better render quality while rendering under UHD monitor resolution.
But most importantly (and I showed that many times already), the GI flickering, which comes from small emissive objects is totally suppressed with DSR hack.
I just do not want to post that video 101st time. But if anyone is interested I will post it again.
wildstar
wildstar
Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)
Last Active: 9 Months Ago
Posts: 1.2K, Visits: 5.1K
Alasandro
Alasandro
Posts: 80, Visits: 1.5K
Rockoloco666
Rockoloco666
Group: Banned Members
Posts: 762, Visits: 2.0K
The dsr hack will not work for indigo, indigo works differently from iclone
Ascensi
Ascensi
Posts: 262, Visits: 1.9K
Does this hack only work for iClone? has anyone tried this with Indigo Renderer? I may have a go at this and see if there is any improvement.
Store Page Link
https://forum.reallusion.com/uploads/images/906a14b0-c792-4382-99ee-7dfe.jpg
AMD 4.5 GHz 16 Cores  | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
Last Active: Last Week
If all these images are ending up at 1080P, are we just fooling ourselves here?
If you rendered a 4K image, or video, and then re-sized it 1K, your going to have a smoother image because of the re-sampling of the image. Correct?
Test it by not setting the DSR, and rendering/resizing from 4K to 1K.
TonyDPrime
TonyDPrime
Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)
Posts: 3.4K, Visits: 12.4K
rogyrue (7/26/2017)
So i tested this out and it turns out wildstar is correct there is a hugh difference in render times i shall eat humble pie . I took a still frame from 4 different renders of a animation.Used a complex ship and stuck a bright light on it to show the edges and lines clear.Used standard  1080p and set SS to 3 and took a long time  to render the animation. Second render set render DSR to x4 in  Nvidia panel and export setting in Iclone to Ultra HD no SS and i got a very quick render with almost  the same image quality as the 1080p with SS set to 3.
As wildstar says looks like Nvidea process uses the GPU alot more effectively than Iclone SS setting does . So suppose its best to set up you animation on 1080p standard then for render go to Nvidia set DSR to x4 and screen res to 3840x2160 in Nvidea panel and launch ilcone and render out your scence at Ultra HD with no SS.
Made a mistake in wording on pictures should say DSR not DSE :)
https://forum.reallusion.com/uploads/images/98c51d1c-3247-41d4-9c10-f678.pnghttps://forum.reallusion.com/uploads/images/82546209-d202-4b11-9a10-d800.pnghttps://forum.reallusion.com/uploads/images/84e4df95-e0a4-44a2-92b1-1066.png
Love the images!  Great work on the brightness/contrast in the blue glow areas.  The size is perceptible and definitely gives it a very dramatic feel
-Tony D..
rogyru
rogyru
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Posts: 497, Visits: 1.3K
TonyDPrime
TonyDPrime
Peter (RL) (7/26/2017)
Thank you all  for sharing your findings. Please be assured this will all be reviewed and tested by the iClone team to see how we can improve the rendering process.
Hi Peter!
Thanks very much again for taking into consideration findings by Wildtsar, I agree he offers an excellent vision of ideas for what is possible with iClone 7's rendering process.  I have found the information provided by him very valuable, and am excited to see iClone 7's amazing potential continuing to evolve!
-Tony D.
3
4
