Jfrog
Visits: 4.7K
I created a character with Toonmaker 1 in Iclone 7. 1-I can't open the character in Iclone 6 (this is not too bad my goal is to stick to Iclone 7...) 2-The avatar controller (version 6) creates all kinds of screen flickering while trying to animate the whole face and is unusable. This is true with many characters, not only the one I just created. Is there any avatar controller v7 for Iclone 7? Is it possible for someone to confirm this bug so I can forward it to Reallusion? Thank you in advance.
Ryzen R9 5950x, RTX 3090, 128Gb Ram ,2 x 2 TB Samsung 980 Pro M.2 SSD
Horror Stories in VR Immersive Sound VR Immersive Sound VR on Oculus TV
Posts: 23.1K,
Visits: 36.6K
Hi... We will look into this but you can tell us if the issue affects the default Toon Maker 1 characters or only characters that have been customised. Also could you post a screenshot showing the issue. It is much easier to determine the problem when you can see exactly what is happening. Thanks.
Jfrog
Visits: 4.7K
Hi Peter, I am not in front of my computer now but I did more test today and this is also true with ToonMaker 2 and the Monster Workshop. Those same characters works well in Iclone 6. I can send a picture but a video would be easier to troubleshoot. I will send a few screenshot to show the problem tomorrow. In the meantime I open a support ticket with Reallusion. :) Thank you.
Jfrog
Visits: 4.7K
Here are some screenshots. The first screenshot is before I start moving the puppet controller, than the screen flickering starts while I move the puppet stick around. The problem is only with the full facial expression selection, not with eyes only, ears only etc... I also sent those files thru the support ticket but I guess it doesn't hurt to try the forum too. ;)
Posts: 23.1K,
Visits: 36.6K
Thanks for supplying your screenshots. Unfortunately I'm not encountering those issues with a similar spec computer so It is puzzling. Do you have your graphics drivers up to date? It would be worth checking for newer drivers as this could be the problem.
Jfrog
Visits: 4.7K
I have the driver version 22.21.13.8253
Posts: 23.1K,
Visits: 36.6K
EDIT:
We have now been able to identify the problem and plan to fix it as soon as possible via an update. As soon as I have more information about when this will be I will update again to let you know.
Thank you for your patience and understanding.
Jfrog
Visits: 4.7K
Thank you for the support Peter.
Bigus
Visits: 1.8K
I have also encountered the same problem. Thank you for taking this to your attention.
Embrace simplicity Reduce selfishness Have few desires (Lao Tzu)
Jfrog
Visits: 4.7K
We have now been able to identify the problem and plan to fix it as soon as possible via an update.A s soon as I have more information about when this will be I will update again to let you know. Thank you for your patience and understanding.
Hi Peter,
Any news about that? I think reallusion should make this a priority. It's been already more than a month and no update has been release yet to solve this issue. Reallusion also closed the ticket I opened more than a month ago about this problem. This is causing many delays in our production workflow. I really hope Reallusion understand and release an update quickly.
Thank you for listening.
