cynsegura
cynsegura
Visits: 1.1K
Hi guys! Where Can I get the new t profile for genesis 8? Is there someone who can share with me?
Thanks
pruiz
Visits: 1.8K
wendyluvscatz (7/15/2017) you need the G3F not G2F duf preset I must have mistyped that will go back and correct itThanks. I re-read the whole thread and noticed that someone later corrected that. Yes the G3F works well - there is this left eye twitch that occurs intermittently.
wendyluvscatz
wendyluvscatz
Last Active: 3 Months Ago
Posts: 2.5K,
Visits: 19.4K
pruiz
Visits: 1.8K
wendyluvscatz (6/15/2017) yes she does if you apply the genesis 2 female duf pose from Reallusion her expressions match the bounce can be added to any unused bones by selecting the face icon in the retargetting room and adding to extend bone. Then in main room go to spring open it, select those bones and click the button on far right.I seem not to be able to get expressions - I load the G2 duf pose. Am I supposed to activate something in 3dxchange? The face bone? Thanks for the tips and advice here.
Ardent Enterprise
Ardent Enterprise
Last Active: 8 Years Ago
Visits: 57
I can't thank you enough for this! I am fairly new to iClone and 3DXchange ... I just upgraded to 7 on both and purchased Victoria 8 for a special project. I've been days trying to fix the rig thinking could. I finally submitted a ticket to Support Desk, they sent me your solution here ... wish I had checked earlier last night, I might have gotten some sleep! It took all of five minutes and I finally have the "tiny dancer" I needed for my project! She is a beautiful, fluid model, and well worth the expense now. With heartfelt appreciation! Constance
Constance
Last Active: 2 days ago
Visits: 31.4K
If it works and you like (and can afford) Maya, that may be a solution for you. I believe you need the full version of Maya (not LE) to run plugins.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
I use Draagonstoms script to convert G2F animation to 3 and it sort of works but I would just use Genesis 2 given the choice myself
dr.zap
dr.zap
Visits: 824
will2power71 (7/1/2017)
Flipbook Market creates a lot of animations for DAZ studio and posted a tutorial on how to use Genesis 3 with Motionbuilder you can view Here It's a bit lengthy, but there's some good information on doing it. Webanimate offers some information on doing it as well, but to be honest I don't use Webanimate. I've heard a lot of good things about them. I've done both of these. I am on day 6 of my webanimate trial. I used Genesis 2 with it and it had problems until I contacted support and sent them a Genesis 2 .fbx model. They modified it (detached the root bone?) and sent it back. It works fine now, except for animations with a different skeleton structure. Then it's kind of wonky. I did the same in Motionbuilder but it wasn't my computer so I couldn't finish the retargeting process. It is a lot more complicated, though. I would be happy to use webanimate as a retargeting app (its very simple) if I can get a source for compatible .bvh files. That's why I'm so excited about iKinema Orion. It seems elementary that they will make Orion easily connect to webanimate. I already contacted support and they said that their solver will output to iClone and Daz3d compatible skeletons.
dr.zap
dr.zap
Visits: 824
Then there is this: http://www.3dtoall.com/products/daztomaya/If this flies, I'm not sure why I need iClone. For previz, maybe?
dr.zap
dr.zap
Visits: 824
wendyluvscatz (7/1/2017) sorry to disappoint but getting them back into DAZ studio is not possible, DAZ's FBX import is abysmal they will be a scrunchy pulled apart mess. You can do BVH export but not for Genesis 3 or 8, they will not load it except for a couple weird bone movements.I don't want to hijack your thread, but I have just another question. Have you tried transferring the .bvh to a G2 figure in Daz and then using the transfer pose/anim to G3 plugin? I heard it was good at G2 to G3 transfers. <edit> Ok, I just read Will2power71's comment. It seems he was suggesting the same thing. It might work.
